home:project:midi_router
MIDI Router
Intro
Midi Router is a project which allows you to route MIDI messages to/from multiple MIDI ports on the MIDIbox
Please, if you decide to build a midirouter, take some photos before and after you put it in a case. Add them to a new forum topic and link1) it from here. Add any other info like what version of board was used and midirouter version etc…it helps newbies a lot.
Also, if you are reading this and have built a midirouter that you created, it'd be cool if you take a photo too and insert a link to it from here.
Features
Up to 8 MIDI I/Os
Customisable routing through simple C code
Skills / Equipment Required
Hardware
What modules do I need?
Parts List
List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links
Where to buy Parts
Connections
Connection diagrams - links if needed (create in you projects namespace
Enclosure / Case
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
Enclosure References
Software
Setting Up
We recommend you read software before you continue.
Download
Links
Setup Instructions
Up to you
Extra
Usage Manual
Anything else
1)
It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.
home/project/midi_router.txt · Last modified: 2011/07/22 14:52 by digineural
