how_to_mix_c_and_asm
Differences
Link to this comparison view
Both sides previous revision Previous revision
how_to_mix_c_and_asm [2008/09/10 17:31]
audiocommander code plugin disappearance is killing me :/
how_to_mix_c_and_asm [2008/09/29 12:27]
wackazong
Line 1: Line 1:
-It's actually quite easy!
-As you can see in the example below, just enclose the ASM part with //​_////​_asm//​ and //​_////​_endasm;//​
-You might have to declare some additional variables, but the concept is quite straightforward.
-<code c>
-unsigned char Scale_7bit(unsigned char evnt2, unsigned char min, unsigned char max) {
-  // scaled value is (<8-bit random> * ) >> 8
-  PRODL = evnt2 << 1; // 8bit value
-  PRODH = max-min+1; ​ // range
-__asm
-    movf _PRODL, W
-    mulwf _PRODH, 0
-__endasm;
-  return min + PRODH;
-</​code>​
-Also, as well as the above example of '​inline ASM', it is possible to include ASM code in .inc include files, and call that ASM code from within your C application. Please see the forum thread [[http://​www.midibox.org/​forum/​index.php?​topic=7698.0|using assembler in C - question about _ in front of macro names]] for more info.
how_to_mix_c_and_asm.txt ยท Last modified: 2008/09/29 12:27 by wackazong
