Both sides previous revision Previous revision | |||
installing_gputils_and_sdcc_on_debian_linux [2011/07/26 06:34] oswaldojackson |
installing_gputils_and_sdcc_on_debian_linux [2011/07/27 15:45] digineural Removed Spam |
Line 37: | Line 37: | ||
Note: The biggest issues you'll have with this HowTo is that there are certain dependencies in building these sorts of things that you will have to install. Sometimes it will say that it can't without something specific like "bison", which you can easily install using "apt-get install bison"; but other times it only references a binary inside a package of a DIFFERENT name. This means that you'll have to search around a bit, maybe using "apt-cache search foo" or maybe also on the internet to figure out what package you need to install. | Note: The biggest issues you'll have with this HowTo is that there are certain dependencies in building these sorts of things that you will have to install. Sometimes it will say that it can't without something specific like "bison", which you can easily install using "apt-get install bison"; but other times it only references a binary inside a package of a DIFFERENT name. This means that you'll have to search around a bit, maybe using "apt-cache search foo" or maybe also on the internet to figure out what package you need to install. | ||
- | [[http://customcollegeessays.com/index.php|college essay]] | ||
