M16 Interface
Add 16 MIDI I/O to your Core, SPI Slave Interface with up to 16 UARTs(MIDI I/O), based on low-cost FPGA…
toDo
Some connection examples\\
Spi slave, share protocol
and added commands
Features
The FPGA internal clock works @88.67MHz.
Fast 4 wires SPI in slave mode to control the board, 10Mb/s.
Uses the default MIOS32_SPI_MIDI protocol, MIOS32 is ready-to-use with it.
16 UARTs on board, it's 16 MIDI ports.
Each MIDI output has its own FIFO buffer of 1024 bytes, to queue the incoming MIDI from the SPI.
Each MIDI output has its independent “Running Status”, with Disable/Enable Command from SPI.
There's a 64 word(32bits) FIFO for out-coming messages from the board.
3 independents groups of 16 GPIOs, configurable and settable by SPI Command.
In MIOS32
datasheet
