To build the front panel of MIDIbox Quad Genesis, you will need (details on each part below):
Here is the design I used to manufacture the aluminum front panel for my synth: mbqg_fp_original.fpd (You will need to be logged in to your MIDIbox Forum account to access these downloads)
Here is a modified design with the LED pipes in the LED rings having been replaced by 3mm LEDs just sticking through holes in the aluminum: mbqg_fp_modledrings.fpd
It took me over 2 hours just to insert the tiny LED pipes in the slits in one single front panel with the first design, which is why I recommend the second. Since they're 3D printed (see below), they have a small range of sizes, and at that scale some are too big and some are too small. I still left them in place for the FM widget and the DAC VU meter; if you don't want those either for some reason, it shouldn't be hard to replace them with holes.
All the LED holes and screw mounting holes are 1/8“ (3.17 mm), which should give 3mm LEDs a little play (some are in practice slightly wider than 3mm, and some aren't actually 3mm at all). On my own panel, I had to drill out some of the holes a bit for the yellow and green LEDs sticking through the front panel; I recommend you buy the LEDs you're going to put through the holes first and measure them before you have the front panel manufactured. These holes are also big enough for both M3 and 4-40” screws, so no problem there.
It may be possible to make the front panel out of acrylic, a-la MIDIbox SEQ V4. Since the front panel PCB is bolted to it in many places, it will probably be sturdy enough. If it's not, there's a row of screw holes slightly below halfway down the panel, and maybe you can have those screws go into an aluminum bar spanning the width of the front panel and attaching to the sides of your case, to provide extra support in the middle.
A custom front panel PCB is purchaseable directly from Sauraen for $50 plus at-cost shipping. It includes a free detachable MBHP_GENESIS_LS PCB in the space where the volume knobs will be on the front panel. Contact Sauraen by private message at the MIDIbox Forums or post in the MIDIbox Quad Genesis thread there.
This is the set of parts I used to build the two MIDIbox Quad Genesis units I constructed. It can also serve as guidelines for if you're building your own board from scratch on veroboard. Here are some notes and caveats:
Description | Mouser P/N | Quantity |
Encoders; 0.1“ board mount with switch; bushing; 24 PPR, 24 detent; etc. If you want to save a couple dollars, you can use the ones without the switch for all the encoders except the datawheel and the four Operator Level encoders–those are the only ones for which the switch is wired up. | 652-PEC12R3220FS0024 | 21 |
Tact switches; standard, 5mm high | 611-PTS645SM502 | 115 |
Diodes for button matrix | 583-1N4148-T | 120 |
Red LEDs for lighting buttons/caps (4500mcd (!)) | 604-WP710A10SRC/J4 | 87 |
Orange LEDs for lighting buttons/caps (2700mcd (!)) | 604-WP710A10SEC | 9 |
Yellow LEDs for lighting buttons/caps (3200mcd (!)) | 859-LTL17KYV3JS | 24 |
Green LEDs for lighting buttons/caps (7200mcd (!)) | 859-LTL17KTGX3KS | 74 |
Blue LEDs for lighting buttons/caps (1500mcd (!)) | 859-LTL17KTBS3KS | 220 |
Red LEDs for panel indication (i.e. sticking through holes in front panel) (Tinted, Diffused) | 604-WP710A10SRD/D | 26 |
Orange LEDs for panel indication (Tinted, Diffused) | 696-SSL-LX3044SOD | 7 |
Yellow LEDs for panel indication (Tinted, Diffused) (For some reason I ended up using these only for the yellow LEDs in the commands display and the load meter, not for the crosspoints in the FM widget; it may have been because I wanted clear-looking LEDs in the FM widget to go with all the other clear/white things there, or because these LEDs are closer to yellow than to amber, and the other LEDs in the FM widget were more amber) | 710-151031YS06000 | 23 |
Green LEDs for panel indication (Tinted, Clear–I couldn't get appropriate brightness diffused ones) | 859-LTL1CHJGTNN | 51 |
Blue LEDs for panel indication (NOT tinted, Diffused–the picture lies, they're white diffused but light up blue; and actually these are a bit too bright to use for sticking through the front panel. You could fudge something with the resistors supplying these columns to try to reduce the brightness, but I might recommend looking for alternative LEDs.) | 593-VAOL-3LSBY1 | 28 |
Red/Green 5mm LEDs for FM widget operator nodes (3 wire common ANODE) | 696-LLX5099SRSGCCA | 4 |
Large LED display | 859-LTC-5623HR | 1 |
Small LED displays | 859-LSHD-7501 | 5 |
Row drive NMOSFETs (2n7000s aren't strong enough) | 689-VN3205N3-G | 8 |
74HC595 shift registers, SOIC-16 | 511-M74HC595YRM13TR | 12 |
74HC165 shift registers, SOIC-16 | 863-MC74HC165ADR2G | 8 |
220 ohm x 8 resistor packs, SOIC-16 | 652-4816P-1LF-220 | 11 |
10k ohm x 4 resistor packs, SIL-5 (RP13–RP28, not RP0 and RP1) | 858-L051S103LF | 16 |
1k ohm x 4 resistor packs, SIL-5 (these are just RP0 and RP1) | 652-4605X-1LF-1K | 2 |
Electrolytic caps (470 uF) | 647-UVR1C471MPD | 3 |
Ceramic/film caps (0.1 uF) | Buy by the 100 from eBay | ~20 |
10k dual gang audio taper panel mount pot (OPN2 volume) | 313-1240F-10K | 1 |
10k audio taper panel mount pot | 858-P160KNPC15A10K | 1 |
5×2 pin header | Buy in larger size (preferably from eBay) and snap off | 1 |
Don't forget: the 2×40 character LCD, the pin header for the LCD, the ribbon cable and IDC connectors for the LCD and front panel, knob caps for the regular encoders, datawheel knob cap for the datawheel, knob caps for the volume pots.
Schematic image (unfortunately, MIDIbox Gallery scaled down the original image, and offsite documentation is frowned upon):
Front panel KiCad project coming soon!
For Color fields, as discussed above, you may change the colors to whatever you want, but it is recommended to keep the colors consistent (e.g. make everything “green” below be the same color, and everything “red” below be a different color). For the Red/Green buttons below, the Red LED is always on the left and the Green LED is always on the right.
Ref. Des. | Type | Color | Description |
A1 | Encoder + 16-LED ring | Blue | FM operator parameter “Harmonic” (“FMult”) |
A2 | Encoder + 7-LED ring | Rainbow | FM operator parameter “Detune” |
A3 | Encoder + 16-LED ring | Blue | FM operator parameter “Atk Rate” |
A4 | Encoder + 16-LED ring | Blue | FM operator parameter “Dec1 Rate” |
A5 | Encoder + 16-LED ring | Blue | FM operator parameter “Dec1 Level” |
A6 | Encoder + 16-LED ring | Blue | FM operator parameter “Dec2 Rate” |
A7 | Encoder + 16-LED ring | Blue | FM operator parameter “Rel Rate” |
A8 | Encoder + 16-LED ring | Blue | OPN2 parameter “Ch3 CSM Freq” |
A9 | Encoder + 16-LED ring | Blue | PSG voice parameter “Freq” |
A10 | Encoder + 16-LED ring | Blue | PSG voice parameter “Volume” |
A11 | Button + LED | Red | FM operator parameter “KSR” (Key Scale Rate) |
A12 | Button + LED | Red | FM operator SSG-EG parameter “On” |
A13 | Button + LED | Red | FM operator SSG-EG parameter “Init” |
A14 | Button + LED | Red | FM operator SSG-EG parameter “Toggle” |
A15 | Button + LED | Red | FM operator SSG-EG parameter “Hold” |
A16 | Button + LED | Red | FM operator parameter “LFO AM” (LFO → operator amplitude modulation toggle) |
A17 | Button + LED | Red | OPN2 parameter “Ch3 CSM Fast” (originally Timer A fast, now Timer A enable) |
A18–A21 | Encoder + 16-LED ring | Blue | FM voice parameter “Oper 1 Level” – “Oper 4 Level” |
A22 | Encoder + 8-LED ring | Blue | FM voice parameter “LFO-Freq Depth” (LFO → frequency modulation depth) |
A23 | Encoder + 4-LED ring | Blue | FM voice parameter “LFO-Amp Depth” (LFO → amplitude modulation depth) |
A24 | Encoder + 8-LED ring | Blue | OPN2 parameter “LFO Freq” |
A25 | Button + LED | Red | OPN2 parameter “Ugly” (now-famous test bit 0x21:4) |
A26 | Button + LED | Red | OPN2 parameter “DAC Override” (test bit 0x2C:5) |
A27 | Button + LED | Red | OPN2 parameter “LFO Enable” |
A28 | Button + LED | Red | OPN2 parameter “EG Enable” (invert of test bit 0x21:5) |
A29–A32 | Button + LED | Green | Operator Selection 1–4 |
A33–A44 | Button + 2 LEDs | Red/Green | Genesis 1 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A45–A56 | Button + 2 LEDs | Red/Green | Genesis 2 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A57 | Encoder + 8-LED ring | Blue | OPN2 voice parameter “Feedback” |
A58–A69 | Button + 2 LEDs | Red/Green | Genesis 3 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A70–A81 | Button + 2 LEDs | Red/Green | Genesis 4 Voice Selection: DAC, FM voices 1–6, OPN2 globals, PSG voices 1-3, noise |
A82 | Button + LED | Red | OPN2 parameter “DAC Enable” |
A83 | Button + LED | Green | System Mode |
A84 | Button + LED | Green | Voice Mode |
A85 | Button + LED | Green | Channel Mode |
A86 | Button + LED | Green | Program Mode |
A87 | Button + LED | Green | VGM Editor Mode |
A88 | Button + LED | Green | Modulator Mode |
A89 | Button + LED | Green | Sample Mode |
A90 | Button + LED | Red | Mute |
A91 | Button + LED | Red | Solo |
A92 | Button + LED | Red | Release |
A93 | Button + LED | Red | Panel Override |
A94 | Button + LED | Green | Restart |
A95 | Button + LED | Green | Play |
A96 | Button + LED | Green | Reset |
A97 | Button + LED | Green | Load |
A98 | Button + LED | Green | Save |
A99 | Button + LED | Green | New |
A100 | Button + LED | Green | Delete |
A101 | Button + LED | Green | Crop |
A102 | Button + LED | Green | Capture |
A103 | Button + LED | Green | Duplicate |
A104 | Button + LED | Green | Paste |
A105 | Button + LED | Red/Green | Ctrl |
A106 | Button + LED | Red/Green | Time |
A107 | 7-LED Column | Red | VGM Commands Display: Ctrl |
A108 | 7-LED Column | Red | VGM Commands Display: Time |
A109 | 7-LED Column | Yellow | VGM Commands Display: OPN2 |
A110 | 7-LED Column | Green | VGM Commands Display: FM 1 |
A111 | 7-LED Column | Green | VGM Commands Display: FM 2 |
A112 | 7-LED Column | Green | VGM Commands Display: FM 3 |
A113 | 7-LED Column | Green | VGM Commands Display: FM 4 |
A114 | 7-LED Column | Green | VGM Commands Display: FM 5 |
A115 | 7-LED Column | Green | VGM Commands Display: FM 6 |
A116 | 7-LED Column | Orange | VGM Commands Display: DAC |
A117 | 7-LED Column | Blue | VGM Commands Display: OP/SQ 1 |
A118 | 7-LED Column | Blue | VGM Commands Display: OP/SQ 2 |
A119 | 7-LED Column | Blue | VGM Commands Display: OP/SQ 3 |
A120 | 7-LED Column | Blue | VGM Commands Display: OP4/NS |
A121 | Button + LED | Green | Commands View |
A122 | Button + LED | Green | State View |
A123 | Button + LED | Red | Group |
C1–C20 | Capacitor | N/A | 0.1uF ceramic or film capacitors for chips |
C21–C23 | Capacitor | N/A | 470uF electrolytic capacitors for power rails, reverse mounted |
D1–D5 | Diode | N/A | Diodes for encoder buttons; all normal button diodes included in Assembly or Switch |
DS1 | LED Display | Red | Main Display |
DS2 | LED Display | Red | Octave |
DS3–DS6 | LED Display | Red | Frequency |
E1 | Encoder | N/A | OPN2 voice parameter “Octave” |
E2 | Encoder | N/A | OPN2 voice parameter “Frequency” |
E3 | Encoder | N/A | Datawheel |
LD1–LD3 | LED | Red | OPN2 Ch3 Mode |
LD4–LD7 | LED | Red | PSG Noise Freq |
LD8–LD9 | LED | Red | PSG Noise Type |
LD10, LD16 | LED | Yellow | FM Voice Output |
LD11–LD14, LD24–LD29, LD37–LD40, LD48–LD49 | LED | Yellow | FM Widget Path |
LD15, LD17, LD22, LD23, LD30, LD31, LD36, LD42, LD44 | LED | Orange | DAC VU Meter |
LD18–LD21 | Bicolor LED | Red/Green | FM Widget Operator Node |
LD33–LD35, LD45–LD46, LD51 | LED | Yellow | FM Widget Path Node |
LD32 | LED | Red | FM Widget Feedback |
LD41, LD43, LD47, LD50 | LED | Yellow | Key On |
R1–R2 | Resistors | N/A | 2.2k terminating resistors for clock and latch lines |
RP0–RP1 | Resistor Packs | N/A | 1k row driver pull-ups (to reduce ghosting) |
RP2–RP12 | Resistor Packs | N/A | 220 ohm LED column current limiters |
RP13–RP28 | Resistor Packs | N/A | 10k button column pull-ups |
S1 | Button | N/A | OPN2 Ch3 Mode |
S2 | Button | N/A | PSG Noise Freq |
S3 | Button | N/A | PSG Noise Type |
S4 | Button | N/A | FM Voice Output |
S5 | Button | N/A | Algorithm |
S6 | Button | N/A | Key On |
S7 | Button | N/A | Mark Beginning |
S8 | Button | N/A | Move Up |
S9 | Button | N/A | Up One Command |
S10 | Button | N/A | Up One State |
S11 | Button | N/A | Mark End |
S12 | Button | N/A | Move Down |
S13 | Button | N/A | Down One Command |
S14 | Button | N/A | Down One State |
S15 | Button | N/A | Menu |
S16–S23 | Button | N/A | Softkeys |
S24 | Button | N/A | Enter |
TF1 | Triforce | Red | Triforce of Power |
TF2 | Triforce | Blue | Triforce of Wisdom |
TF3 | Triforce | Green | Triforce of Courage |
U1–U12 | IC | N/A | 74HC595 Output Shift Register, SMD |
U13–U20 | IC | N/A | 74HC165 Input Shift Register, SMD |
This is the mapping for the MBQG_FP board itself–if you have the commercially produced PCB from Sauraen, you don't need this info because it's already in the copper!
MIDIbox Quad Genesis supports its front panel controls in any valid MIDIbox button-LED matrix configuration, with the following restrictions:
For now, the mapping is hard-coded in frontpanel.c, but eventually (if there is interest), it will be read from a text-based configuration file on the SD card upon startup. If you match the matrix maps below, you won't need to edit this at all.
Syntax:
All LED display digits are wired, from rows 0 to 7: A-B-C-D-E-F-G-DP
VGM Commands Matrix is wired, from top to bottom, 0-1-2-3-4-5-6 (row 7 not used for any columns)
Counting the individual segments in the LED displays, there are 638 LEDs on the front panel.
SR | IDX | BIT | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 |
U1 | 1 | 0 | ROW0 DRIVER (ACTIVE HIGH) | |||||||
1 | ROW1 DRIVER (ACTIVE HIGH) | |||||||||
2 | ROW2 DRIVER (ACTIVE HIGH) | |||||||||
3 | ROW3 DRIVER (ACTIVE HIGH) | |||||||||
4 | ROW4 DRIVER (ACTIVE HIGH) | |||||||||
5 | ROW5 DRIVER (ACTIVE HIGH) | |||||||||
6 | ROW6 DRIVER (ACTIVE HIGH) | |||||||||
7 | ROW7 DRIVER (ACTIVE HIGH) | |||||||||
U2 | 2 | 0 | LR_G1_DAC | LG_G1_DAC | LR_G2_DAC | LG_G2_DAC | LR_G3_DAC | LG_G3_DAC | LR_G4_DAC | LG_G4_DAC |
1 | LR_G1_V1 | LG_G1_V1 | LR_G2_V1 | LG_G2_V1 | LR_G3_V1 | LG_G3_V1 | LR_G4_V1 | LG_G4_V1 | ||
2 | LR_G1_V2 | LG_G1_V2 | LR_G2_V2 | LG_G2_V2 | LR_G3_V2 | LG_G3_V2 | LR_G4_V2 | LG_G4_V2 | ||
3 | LR_G1_V3 | LG_G1_V3 | LR_G2_V3 | LG_G2_V3 | LR_G3_V3 | LG_G3_V3 | LR_G4_V3 | LG_G4_V3 | ||
4 | LR_G1_V4 | LG_G1_V4 | LR_G2_V4 | LG_G2_V4 | LR_G3_V4 | LG_G3_V4 | LR_G4_V4 | LG_G4_V4 | ||
5 | LR_G1_V5 | LG_G1_V5 | LR_G2_V5 | LG_G2_V5 | LR_G3_V5 | LG_G3_V5 | LR_G4_V5 | LG_G4_V5 | ||
6 | X | X | X | X | LFOFREQ_O4 | LFOFREQ_O5 | LFOFREQ_O6 | LFOFREQ_O7 | ||
7 | X | X | X | X | LFOFREQ_O11 | LFOFREQ_O10 | LFOFREQ_O9 | LFOFREQ_O8 | ||
U3 | 3 | 0 | LR_G1_V6 | LG_G1_V6 | LR_G2_V6 | LG_G2_V6 | LR_G3_V6 | LG_G3_V6 | LR_G4_V6 | LG_G4_V6 |
1 | LR_G1_OPN2 | LG_G1_OPN2 | LR_G2_OPN2 | LG_G2_OPN2 | LR_G3_OPN2 | LG_G3_OPN2 | LR_G4_OPN2 | LG_G4_OPN2 | ||
2 | LG_CTRL | X | LR_CTRL | X | LG_TIME | L_CMDS | LR_TIME | L_STATE | ||
3 | L_GROUP | L_MUTE | L_RESTART | L_SOLO | L_PLAY | L_RELEASE | L_RESET | L_PNLOVR | ||
4 | LR_G1_S1 | LG_G1_S1 | LR_G2_S1 | LG_G2_S1 | LR_G3_S1 | LG_G3_S1 | LR_G4_S1 | LG_G4_S1 | ||
5 | LR_G1_S2 | LG_G1_S2 | LR_G2_S2 | LG_G2_S2 | LR_G3_S2 | LG_G3_S2 | LR_G4_S2 | LG_G4_S2 | ||
6 | LR_G1_S3 | LG_G1_S3 | LR_G2_S3 | LG_G2_S3 | LR_G3_S3 | LG_G3_S3 | LR_G4_S3 | LG_G4_S3 | ||
7 | LR_G1_NOISE | LG_G1_NOISE | LR_G2_NOISE | LG_G2_NOISE | LR_G3_NOISE | LG_G3_NOISE | LR_G4_NOISE | LG_G4_NOISE | ||
U4 | 4 | 0 | X | X | X | X | X | L_CH3NORM | L_CH34FREQ | L_CH3CSM |
1 | X | X | L_EG | L_LFO | L_DACOVR | L_UGLY | L_CH3FAST | X | ||
2 | L_NFMED | L_NFHI | L_KSR | L_SSGON | L_SSGINIT | L_SSGTGL | L_SSGHOLD | L_LFOAM | ||
3 | L_NFSQ3 | L_NFLO | L_NMPLS | L_NMWHT | X | X | X | X | ||
4 | PSGVOL_O15 | PSGVOL_O14 | PSGVOL_O13 | PSGVOL_O12 | PSGVOL_O11 | PSGVOL_O10 | PSGVOL_O9 | PSGVOL_O8 | ||
5 | PSGVOL_O0 | PSGVOL_O1 | PSGVOL_O2 | PSGVOL_O3 | PSGVOL_O4 | PSGVOL_O5 | PSGVOL_O6 | PSGVOL_O7 | ||
6 | PSGFREQ_O15 | PSGFREQ_O14 | PSGFREQ_O13 | PSGFREQ_O12 | PSGFREQ_O11 | PSGFREQ_O10 | PSGFREQ_O9 | PSGFREQ_O8 | ||
7 | PSGFREQ_O0 | PSGFREQ_O1 | PSGFREQ_O2 | PSGFREQ_O3 | PSGFREQ_O4 | PSGFREQ_O5 | PSGFREQ_O6 | PSGFREQ_O7 | ||
U5 | 5 | 0 | RELRATE_O15 | RELRATE_O14 | RELRATE_O13 | RELRATE_O12 | RELRATE_O11 | RELRATE_O10 | RELRATE_O9 | RELRATE_O8 |
1 | RELRATE_O0 | RELRATE_O1 | RELRATE_O2 | RELRATE_O3 | RELRATE_O4 | RELRATE_O5 | RELRATE_O6 | RELRATE_O7 | ||
2 | CSMFREQ_O15 | CSMFREQ_O14 | CSMFREQ_O13 | CSMFREQ_O12 | CSMFREQ_O11 | CSMFREQ_O10 | CSMFREQ_O9 | CSMFREQ_O8 | ||
3 | CSMFREQ_O0 | CSMFREQ_O1 | CSMFREQ_O2 | CSMFREQ_O3 | CSMFREQ_O4 | CSMFREQ_O5 | CSMFREQ_O6 | CSMFREQ_O7 | ||
4 | DECLVL_O15 | DECLVL_O14 | DECLVL_O13 | DECLVL_O12 | DECLVL_O11 | DECLVL_O10 | DECLVL_O9 | DECLVL_O8 | ||
5 | DECLVL_O0 | DECLVL_O1 | DECLVL_O2 | DECLVL_O3 | DECLVL_O4 | DECLVL_O5 | DECLVL_O6 | DECLVL_O7 | ||
6 | DEC2R_O15 | DEC2R_O14 | DEC2R_O13 | DEC2R_O12 | DEC2R_O11 | DEC2R_O10 | DEC2R_O9 | DEC2R_O8 | ||
7 | DEC2R_O0 | DEC2R_O1 | DEC2R_O2 | DEC2R_O3 | DEC2R_O4 | DEC2R_O5 | DEC2R_O6 | DEC2R_O7 | ||
U6 | 6 | 0 | DEC1R_O15 | DEC1R_O14 | DEC1R_O13 | DEC1R_O12 | DEC1R_O11 | DEC1R_O10 | DEC1R_O9 | DEC1R_O8 |
1 | DEC1R_O0 | DEC1R_O1 | DEC1R_O2 | DEC1R_O3 | DEC1R_O4 | DEC1R_O5 | DEC1R_O6 | DEC1R_O7 | ||
2 | ATTACK_O15 | ATTACK_O14 | ATTACK_O13 | ATTACK_O12 | ATTACK_O11 | ATTACK_O10 | ATTACK_O9 | ATTACK_O8 | ||
3 | ATTACK_O0 | ATTACK_O1 | ATTACK_O2 | ATTACK_O3 | ATTACK_O4 | ATTACK_O5 | ATTACK_O6 | ATTACK_O7 | ||
4 | X | X | X | X | DETUNE_O11 | DETUNE_O10 | DETUNE_O9 | DETUNE_O8 | ||
5 | X | X | X | X | X | DETUNE_O5 | DETUNE_O6 | DETUNE_O7 | ||
6 | HARM_O15 | HARM_O14 | HARM_O13 | HARM_O12 | HARM_O11 | HARM_O10 | HARM_O9 | HARM_O8 | ||
7 | HARM_O0 | HARM_O1 | HARM_O2 | HARM_O3 | HARM_O4 | HARM_O5 | HARM_O6 | HARM_O7 | ||
U7 | 7 | 0 | OP1LVL_O0 | OP1LVL_O1 | OP1LVL_O2 | OP1LVL_O3 | OP1LVL_O4 | OP1LVL_O5 | OP1LVL_O6 | OP1LVL_O7 |
1 | OP1LVL_O15 | OP1LVL_O14 | OP1LVL_O13 | OP1LVL_O12 | OP1LVL_O11 | OP1LVL_O10 | OP1LVL_O9 | OP1LVL_O8 | ||
2 | OP2LVL_O0 | OP2LVL_O1 | OP2LVL_O2 | OP2LVL_O3 | OP2LVL_O4 | OP2LVL_O5 | OP2LVL_O6 | OP2LVL_O7 | ||
3 | OP2LVL_O15 | OP2LVL_O14 | OP2LVL_O13 | OP2LVL_O12 | OP2LVL_O11 | OP2LVL_O10 | OP2LVL_O9 | OP2LVL_O8 | ||
4 | FREQUENCY DIGIT 3 COMMON ANODE | |||||||||
5 | FREQUENCY DIGIT 2 COMMON ANODE | |||||||||
6 | FREQUENCY DIGIT 1 COMMON ANODE | |||||||||
7 | OCTAVE DIGIT COMMON ANODE | |||||||||
U8 | 8 | 0 | OP3LVL_O0 | OP3LVL_O1 | OP3LVL_O2 | OP3LVL_O3 | OP3LVL_O4 | OP3LVL_O5 | OP3LVL_O6 | OP3LVL_O7 |
1 | OP3LVL_O15 | OP3LVL_O14 | OP3LVL_O13 | OP3LVL_O12 | OP3LVL_O11 | OP3LVL_O10 | OP3LVL_O9 | OP3LVL_O8 | ||
2 | OP4LVL_O0 | OP4LVL_O1 | OP4LVL_O2 | OP4LVL_O3 | OP4LVL_O4 | OP4LVL_O5 | OP4LVL_O6 | OP4LVL_O7 | ||
3 | OP4LVL_O15 | OP4LVL_O14 | OP4LVL_O13 | OP4LVL_O12 | OP4LVL_O11 | OP4LVL_O10 | OP4LVL_O9 | OP4LVL_O8 | ||
4 | X | X | X | X | LFOFDEP_O4 | LFOFDEP_O5 | LFOFDEP_O6 | LFOFDEP_O7 | ||
5 | X | X | X | X | LFOFDEP_O11 | LFOFDEP_O10 | LFOFDEP_O9 | LFOFDEP_O8 | ||
6 | X | X | X | X | LFOADEP_O4 | LFOADEP_O10 | LFOADEP_O6 | LFOADEP_O8 | ||
7 | FREQUENCY DIGIT 4 COMMON ANODE | |||||||||
U9 | 9 | 0 | X | X | X | X | L_DACB9 | L_DACENAB | LW46 | X |
1 | LW45 | LW48 | LW51 | LW49 | L_KON1 | L_KON2 | L_KON3 | L_KON4 | ||
2 | FEEDBACK_O11 | FEEDBACK_O10 | FEEDBACK_O9 | FEEDBACK_O8 | L_DACB5 | L_DACB6 | L_DACB7 | L_DACB8 | ||
3 | FEEDBACK_O4 | FEEDBACK_O5 | FEEDBACK_6 | FEEDBACK_7 | L_DACB1 | L_DACB2 | L_DACB3 | L_DACB4 | ||
4 | LW32 | LW33 | LW37 | LW38 | LW34 | LW39 | LW40 | LW35 | ||
5 | L_OUTL | L_OUTR | LW24 | LW25 | LW26 | LW27 | LW28 | LW29 | ||
6 | LR_OP1 | LG_OP1 | LR_OP2 | LG_OP2 | LR_OP3 | LG_OP3 | LR_OP4 | LG_OP4 | ||
7 | L_SELO1 | L_CARRO1 | L_SELO2 | L_CARRO2 | L_SELO3 | L_CARRO3 | L_SELO4 | L_CARRO4 | ||
U10 | 10 | 0 | MAIN DIGIT 4 COMMON ANODE | |||||||
1 | MAIN DIGIT 3 COMMON ANODE | |||||||||
2 | MAIN DIGIT 2 COMMON ANODE | |||||||||
3 | MAIN DIGIT 1 COMMON ANODE | |||||||||
4 | L_RAM0 | L_RAM1 | L_RAM2 | L_RAM3 | L_RAM4 | L_RAM5 | L_RAM6 | L_RAM7 | ||
5 | L_CHIP0 | L_CHIP1 | L_CHIP2 | L_CHIP3 | L_CARD3 | L_CARD2 | L_CARD1 | L_CARD0 | ||
6 | L_LOAD | L_CROP | L_SAVE | L_CAPTURE | L_NEW | L_DUPL | L_DELETE | L_PASTE | ||
7 | L_PROG | X | L_VGM | L_SYSTEM | L_MDLTR | L_VOICE | L_SAMPLE | L_CHAN | ||
U11 | 11 | 0 | VGM COMMANDS MATRIX COLUMN 7: FM 4 | |||||||
1 | VGM COMMANDS MATRIX COLUMN 6: FM 3 | |||||||||
2 | VGM COMMANDS MATRIX COLUMN 5: FM 2 | |||||||||
3 | VGM COMMANDS MATRIX COLUMN 4: FM 1 | |||||||||
4 | VGM COMMANDS MATRIX COLUMN 3: OPN2 | |||||||||
5 | VGM COMMANDS MATRIX COLUMN 2: TIME | |||||||||
6 | VGM COMMANDS MATRIX COLUMN 1: CTRL | |||||||||
7 | X | |||||||||
U12 | 12 | 0 | X | |||||||
1 | VGM COMMANDS MATRIX COLUMN 14: OP4/NS | |||||||||
2 | VGM COMMANDS MATRIX COLUMN 13: OP/SQ 3 | |||||||||
3 | VGM COMMANDS MATRIX COLUMN 12: OP/SQ 2 | |||||||||
4 | VGM COMMANDS MATRIX COLUMN 11: OP/SQ 1 | |||||||||
5 | VGM COMMANDS MATRIX COLUMN 10: DAC | |||||||||
6 | VGM COMMANDS MATRIX COLUMN 9: FM 6 | |||||||||
7 | VGM COMMANDS MATRIX COLUMN 8: FM 5 |
U13 | 1 | 0 | OP4LVL ENCODER A | |||||||
1 | OP4LVL ENCODER B | |||||||||
2 | LFOFDEP ENCODER B | |||||||||
3 | LFOFDEP ENCODER A | |||||||||
4 | LFOADEP ENCODER B | |||||||||
5 | LFOADEP ENCODER A | |||||||||
6 | LFOFREQ ENCODER A | |||||||||
7 | LFOFREQ ENCODER B | |||||||||
U14 | 2 | 0 | B_MENU | B_G1_V2 | X | B_G2_V2 | X | B_G3_V2 | B_ENTER | B_G4_V2 |
1 | B_SOFT1 | B_G1_V3 | B_SOFT2 | B_G2_V3 | B_SOFT3 | B_G3_V3 | B_SOFT4 | B_G4_V3 | ||
2 | B_SOFT5 | B_G1_V4 | B_SOFT6 | B_G2_V4 | B_SOFT7 | B_G3_V4 | B_SOFT8 | B_G4_V4 | ||
3 | B_MARKST | B_G1_V5 | B_MOVEUP | B_G2_V5 | B_MARKEND | B_G3_V5 | B_MOVEDN | B_G4_V5 | ||
4 | X | B_G1_V1 | X | B_G2_V1 | X | B_G3_V1 | X | B_G4_V1 | ||
5 | X | B_G1_DAC | X | B_G2_DAC | X | B_G3_DAC | X | B_G4_DAC | ||
6 | B_SELO1 | B_OUT | B_SELO2 | B_ALG | B_SELO3 | B_DACEN | B_SELO4 | B_KON | ||
7 | X | X | X | X | EB_OP1LVL | EB_OP2LVL | EB_OP3LVL | EB_OP4LVL | ||
U15 | 3 | 0 | X | B_G1_V6 | X | B_G2_V6 | X | B_G3_V6 | X | B_G4_V6 |
1 | X | B_G1_OPN2 | X | B_G2_OPN2 | X | B_G3_OPN2 | X | B_G4_OPN2 | ||
2 | X | B_G1_S1 | X | B_G2_S1 | X | B_G3_S1 | X | B_G4_S1 | ||
3 | X | B_G1_S2 | X | B_G2_S2 | X | B_G3_S2 | X | B_G4_S2 | ||
4 | X | B_G1_S3 | X | B_G2_S3 | X | B_G3_S3 | X | B_G4_S3 | ||
5 | X | B_G1_NOISE | X | B_G2_NOISE | X | B_G3_NOISE | X | B_G4_NOISE | ||
6 | B_NSTYPE | B_NSFREQ | B_EG | B_LFO | B_DACOVR | B_UGLY | B_FAST | B_CH3MODE | ||
7 | X | X | B_KSR | B_SSGON | B_SSGINIT | B_SSGTGL | B_SSGHOLD | B_LFOAM | ||
U16 | 4 | 0 | CSMFREQ ENCODER A | |||||||
1 | CSMFREQ ENCODER B | |||||||||
2 | RELRATE ENCODER A | |||||||||
3 | RELRATE ENCODER B | |||||||||
4 | PSGFREQ ENCODER A | |||||||||
5 | PSGFREQ ENCODER B | |||||||||
6 | PSGVOL ENCODER A | |||||||||
7 | PSGVOL ENCODER B | |||||||||
U17 | 5 | 0 | DEC2R ENCODER B | |||||||
1 | DEC2R ENCODER A | |||||||||
2 | DECLVL ENCODER B | |||||||||
3 | DECLVL ENCODER A | |||||||||
4 | DEC1R ENCODER B | |||||||||
5 | DEC1R ENCODER A | |||||||||
6 | FREQ ENCODER B | |||||||||
7 | FREQ ENCODER A | |||||||||
U18 | 6 | 0 | ATTACK ENCODER B | |||||||
1 | ATTACK ENCODER A | |||||||||
2 | DETUNE ENCODER B | |||||||||
3 | DETUNE ENCODER A | |||||||||
4 | HARM ENCODER B | |||||||||
5 | HARM ENCODER A | |||||||||
6 | OCTAVE ENCODER B | |||||||||
7 | OCTAVE ENCODER A | |||||||||
U19 | 7 | 0 | OP2LVL ENCODER B | |||||||
1 | OP2LVL ENCODER A | |||||||||
2 | OP3LVL ENCODER B | |||||||||
3 | OP3LVL ENCODER A | |||||||||
4 | OP1LVL ENCODER B | |||||||||
5 | OP1LVL ENCODER A | |||||||||
6 | FEEDBACK ENCODER B | |||||||||
7 | FEEDBACK ENCODER A | |||||||||
U20 | 8 | 0 | DATAWHEEL ENCODER B | |||||||
1 | DATAWHEEL ENCODER A | |||||||||
2 | X | |||||||||
3 | X | |||||||||
4 | B_CTRL | B_CMDDN | B_CMDUP | B_STATEDN | B_TIME | B_CMDS | B_STATEUP | B_STATE | ||
5 | B_LOAD | B_CROP | B_SAVE | B_CAPTURE | B_NEW | B_DUPL | B_DELETE | B_PASTE | ||
6 | B_GROUP | B_MUTE | B_RESTART | B_SOLO | B_PLAY | B_RELEASE | B_RESET | B_PNLOVR | ||
7 | B_PROG | EB_DATAWHL | B_VGM | B_SYSTEM | B_MDLTR | B_VOICE | B_SAMPLE | B_CHAN |
