MIDIBox CV
a MIDI-to-control voltage converter project
MBHP Hardware Requirements
1 CORE module, 1 analog output module (AOUT, AOUT_LC, or AOUT_NG), 1 DINX1 module.
Recommended: LCD, BankStick.
Documentation
Links
Proposals for additional functions in future firmware versions
(Please add your ideas here:)
One Page Up, one Page Down button should replace the Select button for faster selection of CV output
variable pulselength of gate outs depending on velocity
Use individual CV-Outs for dynamic (eg velocity dependant) triggers or gates
Adress note on to different trigger outs, depending on “velocity zones”, eg to turn on accent or glide by velocity
Save different settings
“Rotate” note assignment in Poly mode (select “four voices” for example, then outputs 1-4 will rotate, advancing always with the next note. “Random” would also be nice. See: Oberheim 4-Voice.)
Vibrato LFO. Freerunning LFO summed into oscillator note output, amount controlled by Mod Wheel, amount= zero to a user-selected maximum. In addition to existing note/pitch wheel summing.
