MIDIdocs
A place to put articles, howtos and guides about the MIDIbox universe. These articles are meant to complement the official user manuals on uCapps.de, going into a bit more depth on core concepts, features, workflows and usecases to help users learn more about how to do fun stuff with their MIDIboxes.
Feel free to add or link your own articles, and help document these amazing devices. Also, feel free to edit existing articles to add to or improve them. It'd be really great if you added something here - the better these devices are documented, the more usable they'll be, and it'll be easier for all of us to learn new things about how they can be used. It's also a great way to give something back to the MIDIbox project if you're not great with code or hardware design. If you don't have a Wiki account, ask in the Documentation Project forum, and hopefully an admin will set you up with an account.
Each MIDIdocs article is linked to its own “Discussion Thread” in the MIDIbox Forums where you can ask questions, make comments or corrections, and discuss the topics in each article.
MIDIbox SEQ V4
uCapps.de Overview
Official User Manual
MIDIbox SEQ Forum
The SEQ V4 is the flagship MIDIbox sequencer. It's really an incredible device. You should build one. Once you've built it, you should
buy TK a beer to thank him for developing and constantly improving this amazing thing, and for offering it to the world as a free and open device.
READ THE MANUAL. Then read it again. The SEQ is a complex device, with a huge number of features. You'll probably have to go over the manual a few times before you start to really understand it. Read through the other documentation on http://www.uCapps.de as well - there's a lot of information there that will help you understand how all the devices, software, and modules in the MIDIbox universe work, and how they fit together. These articles will be more helpful to you if you've already read over the documentation on uCapps.de.
In particular, the Frontpanel section of the User Manual briefly describes what each button does, and the Menu Pages section describes how to use each menu page on your SEQ. The Sessions section gives an overview of how Sessions work on the SEQ. TK has also put together some great Tutorials with audio examples.
Hardware
The MBSEQ_HW.V4 File - This file contains configuration information about your SEQ's hardware - button, LED, and encoder assignments, some low level settings, etc. This file has to be in the root of your SD Card in order for the Wilba Frontpanel to work, and changes may be required to this file to add some of the various MIDIbox modules to extend the functionality of your SEQ.
Basic Concepts
Trigger and Parameter Layers - If you're new to the SEQ, you might be confused about trigger and parameter layers. What do they do? What's the difference?
Configuring Tracks - An introduction to the SEQ's track types, and some info on initializing and provisioning tracks.
Chords - How does the SEQ handle chords? How can you play chords in different keys? A bit of information on the Chord track type.
MUTE and SOLO - Fairly self-explanatory, but there's some functionality you might not be aware of.
Sessions - The Official Manual gives a great overview of SEQ Sessions, and how you might want to use them.
Force-To-Scale - make idiotproof robot music by ensuring that you can't play off-key notes.
What the hell is a Mixer Map? - Mixer Maps are a useful MIDI control feature. You can use them to send MIDI CC and Prog Change messages to your synths, and the SEQ can be programmed to send a series of MIDI messages to your synth whenever pattern changes occur in a song.
Patterns and Songs
Advanced Topics
Hardware Loopbacks - Some interesting things you can do with a MIDI cable connecting one of the SEQ's output ports to one of its inputs. Some functionality is available when the SEQ is set up this way that isn't available with the BUS tracks. Watch out for feedback loops though.
uCapps.de Overview
MIDIbox BLM Forum
The BLM is a button grid control surface with LED feedback that can be used as a controller for the MIDIbox SEQ V4, as well as for the SEQ V4L. The full-size BLM (the “16×16+X”) has a 16×16 button grid, with extra control buttons along the sides. Larger or smaller BLMs are possible - the BLM protocol scales to accommodate different button matrix sizes.
There are many BLM options available. You can build a hardware BLM - some users have designed PCBs, others have used veroboard. Ilmenator has created a 16x4 hardware BLM. A Lemur application is available that provides a virtual BLM on an iPad. BLM emulation software is available for Linux, Windows, and Mac computers. The Lemur app and the emulator software can be downloaded on this page.
Novation Launchpad BLM - Since firmware version 87, the SEQ V4 supports the use of two Novation Launchpads as a
BLM control surface. Two Launchpads form a 16×8+X BLM, and up to four can be connected to make a full 16×16+X control surface. Setup instructions.
MIDIbox SEQ V4 Lite (V4L)
uCapps.de Overview/User Guide
MIDIbox SEQ Forum
In addition to reading the V4L User Guide, it may also be helpful to read over some of the MIDIbox SEQ V4 documentation, since the V4L inherits most of its features from the SEQ V4.
The V4L as a MIDI Processor - It's not just a sequencer! The V4L can also be used to process incoming midi signals. All incoming MIDI can be forced-to-scale, and effects (like delays and LFOs) can be applied to selected channels. With a configuration change, the processed notes can go out on the same channel they came in on.
User Projects
Interesting non-official MIDIbox Projects created by members of the community. There are a ton of these out there, here are a few of the better documented examples:
