If you had an old mbSIDv1 with a CS Step A (5 select button, 1 rotary, and 1 menu button) and you have upgrade it to v2, you can simply have the useful Shift function on menu button when the main menu is displayed.
;; special condition if main menu displayed and menu button pressed, go to shif function btfsc CS_MENU, 7 goto CS_MENU_BUTTON_Shift
CS_MENU_BUTTON_Exec_NoStartup ;; activate/deactivate menu button function bcf CS_MENU_MODE, CS_MENU_MODE_MENU_PRESSED btfss MIOS_PARAMETER2, 0; if button is pressed bsf CS_MENU_MODE, CS_MENU_MODE_MENU_PRESSED ;; special condition if main menu displayed and menu button pressed, go to shif function btfsc CS_MENU, 7 goto CS_MENU_BUTTON_Shift ;; do nothing if button has been depressed btfsc MIOS_PARAMETER2, 0 return
;; exit if we are in main menu btfsc CS_MENU, 7 return
CS_MENU_Exec ;; exit if SID not available btfss CS_STAT, CS_STAT_SID_AVAILABLE return ;; clear CS_SELECT_CTR (so that new message appears immediately) clrf CS_SELECT_CTR ;; clear refresh item counter --- ensures that the whole display will be refreshed clrf CS_MENU_REFRESH_ITEM_CTR ;; exit if we are in main menu ;; btfsc CS_MENU, 7 ;; return ;; execute function ;; calc pointer to function: CS_MENU_TABLES + (CS_MENU*CS_MENU_T_ENTRY_LEN) + CS_MENU_ENTRY_EXEC_OFFSET movlw CS_MENU_T_ENTRY_EXEC_OFFSET call CS_MENU_GetMenuTablesPtr goto MIOS_HLP_IndirectJump
In this way the encoder slow function pressing shift (menu) button work only if you are in main menu, and than turn any CS encoder. Since turning encoder jump the lcd to the referred parameter's menu, the slow function remain set-on since you come back to main menu. The slow encoder speed, pushing shift after (during) the encoder movement do not work.
