wilba_mb_6582_control_surface_construction_guide [2009/10/04 13:28] Wilba |
wilba_mb_6582_control_surface_construction_guide [2014/05/23 17:31] smashtv link fix |
Line 81: | Line 81: | ||
Insert LEDs. **CHECK THEY ARE IN CORRECTLY ALIGNED** | Insert LEDs. **CHECK THEY ARE IN CORRECTLY ALIGNED** | ||
- | The flat side of the LED should match the flat side of the symbol on the PCB. The flat side has the cathode. Also the shorter lead is the cathode. http://en.wikipedia.org/wiki/LED#Considerations_in_use | + | The flat side of the LED should match the flat side of the symbol on the PCB. The flat side has the cathode. Also the shorter lead is the cathode. [[http://en.wikipedia.org/wiki/LED#Considerations_in_use]] |
Put the PCB in the PT-10 case top where the panel would normally go, so the LEDs can be put in without bending the leads. | Put the PCB in the PT-10 case top where the panel would normally go, so the LEDs can be put in without bending the leads. | ||
Line 153: | Line 153: | ||
Continuity check the ribbon cable. Make sure there are NO SHORTS between any two adjacent pins of the ribbon cable joints. Make sure GND and 5V are not connected (the single 2-wire cable). | Continuity check the ribbon cable. Make sure there are NO SHORTS between any two adjacent pins of the ribbon cable joints. Make sure GND and 5V are not connected (the single 2-wire cable). | ||
- | ***Note** Bugfight created a detachable solution by using Right Angled SIL Headers on the base PCB in [[http://www.midibox.org/forum/index.php/topic,9798.msg76472.html#msg76472|this]] thread. | + | ***Note** Bugfight created a detachable solution by using Right Angled SIL Headers on the base PCB in <del>[[http://www.midibox.org/forum/index.php/topic,9798.msg76472.html#msg76472|this]]</del> [[http://midibox.org/forums/topic/9107-i-made-noise-with-my-mb-6582/#entry75065|this]] thread. |
- | Click [[http://www.midibox.org/forum/index.php/topic,11762.msg94800.html#msg94800|here]] for Wilba's advice before considering this alternative strategy. | + | |
+ | Click <del>[[http://www.midibox.org/forum/index.php/topic,11762.msg94800.html#msg94800|here]]</del> [[http://midibox.org/forums/topic/10963-mb-6582-cs-cabling/|here]] for Wilba's advice before considering this alternative strategy. | ||
+ | More interconnect info: [[http://midibox.org/forums/topic/14535-mb-6582-ribbon-cable-question/|forum thread]] - [[http://midibox.org/forums/topic/12900-thicker-gauge-wire-for-cs-pcb-to-pcb/|forum thread]] | ||
**woohoo!** nearly finished! | **woohoo!** nearly finished! | ||
Line 165: | Line 165: | ||
- | ***Note*** Please see Wilbas post [[http://www.midibox.org/forum/index.php/topic,9623.msg70697.html#msg70697|here]], for advice on how to connect the LCD to the control surface. | + | ***Note*** Please see Wilbas post <del>[[http://www.midibox.org/forum/index.php/topic,9623.msg70697.html#msg70697|here]]</del> [[http://midibox.org/forums/topic/14329-mb-6582-lcd-wiring-question/|here]], for advice on how to connect the LCD to the control surface. |
Here is a guide to soldering the wires to the LCD. I suggest "rounding" the cable afterwards, it's easier to identify which wire goes to which pin when it's still a flat ribbon. Also, don't solder the wires INTO the holes, strip, tin and solder tinned ends flat against the pads. | Here is a guide to soldering the wires to the LCD. I suggest "rounding" the cable afterwards, it's easier to identify which wire goes to which pin when it's still a flat ribbon. Also, don't solder the wires INTO the holes, strip, tin and solder tinned ends flat against the pads. |
