MB RTC
I started doing the MBClock for no reason but for fun, but i think it can lead to interesting usage, such as domotic.
well, more exactly, this dev board : (USD $6.90)
http://www.futurlec.com/Mini_DS1307.shtml
This board hold a battery back-up, enabling the time to be maintained even with power disconnected from the board. The DS1307 IC stores time values in separate registers, for years, month, day, hour, minutes and seconds. I suggest to use this board, as it's cheap, it will save you time on building, and debuging :)
Connection to core
Well, that's pretty easy : connect Gnd,Vcc,Sc,Sd to Core J4. (instead of bankstick)
I did not add a pull up resistor between Vcc and Sc (well, in fact i did, but i didnt notice any difference)
The C Program
void GET_TIME(void){
	MIOS_IIC_Start();
	MIOS_IIC_ByteSend(0xd0); // slave address, WRITE
	MIOS_IIC_ByteSend(0x00); // set address pointer to 0
	MIOS_IIC_Stop();//???
	MIOS_IIC_Start();    // start IIC
	MIOS_IIC_ByteSend(0xD1);  // send address - READ
	b0 = MIOS_IIC_ByteReceive();  // read byte
	MIOS_IIC_AckSend();    // send acknowledge
	b1 = MIOS_IIC_ByteReceive();  // read byte
	b2 = MIOS_IIC_ByteReceive();  // read byte
	b3 = MIOS_IIC_ByteReceive();  // read byte
	b4 = MIOS_IIC_ByteReceive();  // read byte
	b5 = MIOS_IIC_ByteReceive();  // read byte
	b6 = MIOS_IIC_ByteReceive();  // read byte
	MIOS_IIC_NakSend();    // send disacknowledge!!! (end the read)
	MIOS_IIC_Stop();    // stop IIC
Demo
Just for fun
I have added a 7Seg led display to show the time in that format “HH:MM:SS:ms”
To keep it simple and documented, i used the Midimon MTC Extension as is.
http://ucapps.de/midimon/mtc_extension.pdf
mb_clock.txt · Last modified: 2007/11/17 16:35 (external edit)
Recent changes RSS feed Creative Commons License Donate Powered by PHP Valid XHTML 1.0 Valid CSS Driven by DokuWiki
