FREERTOS_UTILS
Functions
s32 FREERTOS_UTILS_PerfCounterInit (void)
u32 FREERTOS_UTILS_PerfCounterGet (void)
s32 FREERTOS_UTILS_RunTimeStats (void)
Detailed Description
Utility functions for FreeRTOS
Contains functions for performance stat measurements as desribed under: http://www.freertos.org/index.html?http://www.freertos.org/rtos-run-time-stats.html
In order to enable performance measurements, add following definitions to your mios32_config.h file:
 #define configGENERATE_RUN_TIME_STATS           1
 #define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS  FREERTOS_UTILS_PerfCounterInit
 #define portGET_RUN_TIME_COUNTER_VALUE          FREERTOS_UTILS_PerfCounterGet
Add following include statement to your Makefile:
 # For performance measurings
 include $(MIOS32_PATH)/modules/freertos_utils/freertos_utils.mk
Performance stats can be sent to the MIOS Terminal via:
   FREERTOS_UTILS_RunTimeStats();
e.g. when a special button has been pushed, or a special MIDI event has been received.
Example for a stat table sent to the MIOS Terminal:
 00000072321902 ms | Task                 Abs Time             % Time
 00000072321902 ms | ================================================
 00000072321902 ms |
 00000072321904 ms | Period1mS            113775               5
 00000072321905 ms | IDLE                 836250               42
 00000072321905 ms | MSD                  19461                <1
 00000072321905 ms | Hooks                69434                3
 00000072321905 ms | Hooks                260256               13
 00000072321905 ms | Period1mS_LP         387894               19
 00000072321905 ms | Period1S             34842                1
 00000072321906 ms | MIDI                 199942               10
 00000072321906 ms | Pattern              26228                1
 00000072321906 ms |
Note that this performance measurement method is expensive!!!
It should only be used for debugging purposes!
Function Documentation
u32 FREERTOS_UTILS_PerfCounterGet ( void   )
Add this function via
Returns:
32bit counter value
s32 FREERTOS_UTILS_PerfCounterInit ( void   )
Optionally
 // which MIOS32 timer should be used for performance measurements (0..2)
 #define FREERTOS_UTILS_PERF_TIMER 2
 // at which interval should it be called (interval should be much less than 1 mS!)
 #define FREERTOS_UTILS_PERF_TIMER_PERIOD 10 // uS
Returns:
< 0 if initialisation failed
s32 FREERTOS_UTILS_RunTimeStats ( void   )
Use this function to send the performance stats to the MIOS terminal via MIDI
Returns:
< 0 if MIDI output failed
Generated on Tue May 1 19:42:14 2012 for MIOS32 by  doxygen 1.4.7
