BLM_SCALAR_MASTER
Collaboration diagram for BLM_SCALAR_MASTER:
Data Structures
union  sysex_state_t
Defines
#define SYSEX_DISACK   0x0e
#define SYSEX_ACK   0x0f
#define SYSEX_DISACK_LESS_BYTES_THAN_EXP   0x01
#define SYSEX_DISACK_MORE_BYTES_THAN_EXP   0x02
#define SYSEX_DISACK_INVALID_COMMAND   0x0c
#define SYSEX_BLM_CMD_REQUEST   0x00
#define SYSEX_BLM_CMD_LAYOUT   0x01
#define BLM_TIMEOUT_RELOAD_VALUE   10000
#define BLM_MAX_PACKETS   8
Enumerations
enum  sysex_cmd_state_t { SYSEX_CMD_STATE_BEGIN, SYSEX_CMD_STATE_CONT, SYSEX_CMD_STATE_END }
Functions
s32 BLM_SCALAR_MASTER_Init (u32 mode)
s32 BLM_SCALAR_MASTER_MIDI_PortSet (u8 blm, mios32_midi_port_t port)
mios32_midi_port_t BLM_SCALAR_MASTER_MIDI_PortGet (u8 blm)
blm_scalar_master_connection_state_t BLM_SCALAR_MASTER_ConnectionStateGet (u8 blm)
s32 BLM_SCALAR_MASTER_ButtonCallback_Init (s32(*button_callback_func)(u8 blm, blm_scalar_master_element_t element_id, u8 button_x, u8 button_y, u8 button_depressed))
s32 BLM_SCALAR_MASTER_FaderCallback_Init (s32(*fader_callback_func)(u8 blm, u8 fader, u8 value))
s32 BLM_SCALAR_MASTER_LED_Set (u8 blm, blm_scalar_master_element_t element_id, u8 led_x, u8 led_y, blm_scalar_master_colour_t colour)
blm_scalar_master_colour_t BLM_SCALAR_MASTER_LED_Get (u8 blm, blm_scalar_master_element_t element_id, u8 led_x, u8 led_y)
s32 BLM_SCALAR_MASTER_RotateViewSet (u8 blm, u8 rotate_view)
s32 BLM_SCALAR_MASTER_RotateViewGet (u8 blm)
s32 BLM_SCALAR_MASTER_RowOffsetSet (u8 blm, u8 row_offset)
s32 BLM_SCALAR_MASTER_RowOffsetGet (u8 blm)
s32 BLM_SCALAR_MASTER_NumColumnsGet (u8 blm)
s32 BLM_SCALAR_MASTER_NumRowsGet (u8 blm)
s32 BLM_SCALAR_MASTER_NumColoursGet (u8 blm)
s32 BLM_SCALAR_MASTER_TimeoutCtrSet (u8 blm, u16 ctr)
s32 BLM_SCALAR_MASTER_TimeoutCtrGet (u8 blm)
s32 BLM_SCALAR_MASTER_ForceDisplayUpdate (u8 blm)
s32 BLM_SCALAR_MASTER_MIDI_Receive (mios32_midi_port_t port, mios32_midi_package_t midi_package)
s32 BLM_SCALAR_MASTER_MIDI_TimeOut (mios32_midi_port_t port)
s32 BLM_SCALAR_MASTER_SYSEX_Parser (mios32_midi_port_t port, u8 midi_in)
s32 BLM_SCALAR_MASTER_SendRequest (u8 blm, u8 req)
s32 BLM_SCALAR_MASTER_Periodic_mS (void)
Variables
u16 blm_scalar_master_leds_green [BLM_SCALAR_MASTER_NUM_ROWS]
u16 blm_scalar_master_leds_red [BLM_SCALAR_MASTER_NUM_ROWS]
u16 blm_scalar_master_leds_extracolumn_green
u16 blm_scalar_master_leds_extracolumn_red
u16 blm_scalar_master_leds_extracolumn_shift_green
u16 blm_scalar_master_leds_extracolumn_shift_red
u16 blm_scalar_master_leds_extrarow_green
u16 blm_scalar_master_leds_extrarow_red
u8 blm_scalar_master_leds_extra_green
u8 blm_scalar_master_leds_extra_red
Detailed Description
BLM_SCALAR_MASTER Driver
Define Documentation
Include files Local definitions
Enumeration Type Documentation
Local types
Enumerator:
SYSEX_CMD_STATE_END
Function Documentation
s32 BLM_SCALAR_MASTER_ButtonCallback_Init ( s32(*)(u8 blm, blm_scalar_master_element_t element_id, u8 button_x, u8 button_y, u8 button_depressed)  button_callback_func  )
Installs callback function for BLM16x16 buttons
blm_scalar_master_connection_state_t BLM_SCALAR_MASTER_ConnectionStateGet ( u8  blm  )
Returns connection state to MBHP_BLM_SCALAR:
Returns:
0 no contact yet
1 contact via MIDI protocol
2 contact via simplified Lemur protocol
s32 BLM_SCALAR_MASTER_FaderCallback_Init ( s32(*)(u8 blm, u8 fader, u8 value)  fader_callback_func  )
Installs callback function for faders
s32 BLM_SCALAR_MASTER_ForceDisplayUpdate ( u8  blm  )
Enforces a display update
s32 BLM_SCALAR_MASTER_Init ( u32  mode  )
Initializes the BLM_SCALAR_MASTER driver Should be called from Init() during startup
Parameters:
[in] mode currently only mode 0 supported
Returns:
< 0 if initialisation failed
blm_scalar_master_colour_t BLM_SCALAR_MASTER_LED_Get ( u8  blm,
u8  led_x,
u8  led_y
Returns the current colour of a LED
s32 BLM_SCALAR_MASTER_LED_Set ( u8  blm,
u8  led_x,
u8  led_y,
Sets a LED to the given colour
mios32_midi_port_t BLM_SCALAR_MASTER_MIDI_PortGet ( u8  blm  )
Returns the currently configured MIDI IN/OUT port for MBHP_BLM_SCALAR communication
Returns:
0 no communication
the MIDI port if != 0
s32 BLM_SCALAR_MASTER_MIDI_PortSet ( u8  blm,
Sets the IN/OUT port for MBHP_BLM_SCALAR communication
s32 BLM_SCALAR_MASTER_MIDI_Receive ( mios32_midi_port_t  port,
Receives a MIDI package from APP_NotifyReceivedEvent (-> app.c) if port matches with blm_midi_port
s32 BLM_SCALAR_MASTER_MIDI_TimeOut ( mios32_midi_port_t  port  )
This function is called from NOTIFY_MIDI_TimeOut() in app.c if the MIDI parser runs into timeout
s32 BLM_SCALAR_MASTER_NumColoursGet ( u8  blm  )
Returns the number of colours as reported by the BLM during layout request
s32 BLM_SCALAR_MASTER_NumColumnsGet ( u8  blm  )
Returns the number of columns as reported by the BLM during layout request
s32 BLM_SCALAR_MASTER_NumRowsGet ( u8  blm  )
s32 BLM_SCALAR_MASTER_Periodic_mS ( void   )
This function should be periodically called each mS
handle Timeout
take over update force flag
send LED changes to BLM16x16
send LED changes to extra buttons
s32 BLM_SCALAR_MASTER_RotateViewGet ( u8  blm  )
Returns != 0 if screen currently rotated by 90 grad
s32 BLM_SCALAR_MASTER_RotateViewSet ( u8  blm,
u8  rotate_view
Rotates the Screen by 90 grad
s32 BLM_SCALAR_MASTER_RowOffsetGet ( u8  blm  )
Returns the current row offset
s32 BLM_SCALAR_MASTER_RowOffsetSet ( u8  blm,
u8  row_offset
Sets a row offsets when sending the display data for smaller BLM screens
s32 BLM_SCALAR_MASTER_SendRequest ( u8  blm,
u8  req
This function is called to request the layout
s32 BLM_SCALAR_MASTER_SYSEX_Parser ( mios32_midi_port_t  port,
u8  midi_in
This function parses an incoming sysex stream for MIOS32 commands Called from SysEx hook in app.c
s32 BLM_SCALAR_MASTER_TimeoutCtrGet ( u8  blm  )
Returns:
the current timeout counter
s32 BLM_SCALAR_MASTER_TimeoutCtrSet ( u8  blm,
u16  ctr
Directly sets the timeout counter, e.g. to 0 so that the BLM will be disabled until a newly selected port receives a connection request
Variable Documentation
u16 blm_scalar_master_leds_green[BLM_SCALAR_MASTER_NUM_ROWS]
Global variables
u16 blm_scalar_master_leds_red[BLM_SCALAR_MASTER_NUM_ROWS]
