MIOS32_STOPWATCH
Defines
#define TIM_PERIPHERAL_FRQ   (MIOS32_SYS_CPU_FREQUENCY/4)
#define STOPWATCH_TIMER_BASE   LPC_TIM3
#define STOPWATCH_TIMER_BASE   TIM6
#define STOPWATCH_TIMER_RCC   RCC_APB1Periph_TIM6
#define TIM_PERIPHERAL_FRQ   MIOS32_SYS_CPU_FREQUENCY
#define TIM_PERIPHERAL_FRQ   (MIOS32_SYS_CPU_FREQUENCY/2)
Functions
s32 MIOS32_STOPWATCH_Init (u32 resolution)
s32 MIOS32_STOPWATCH_Reset (void)
u32 MIOS32_STOPWATCH_ValueGet (void)
Detailed Description
Stopwatch functions for MIOS32
Allows to measure delays, which is especially useful for measuring the performance of a function, but also for user relevant features (e.g. Tap Tempo)
Define Documentation
Function Documentation
s32 MIOS32_STOPWATCH_Init ( u32  resolution  )
Initializes the 16bit stopwatch timer with the desired resolution:
  • 1: 1 uS resolution, time measurement possible in the range of 0.001mS .. 65.535 mS
  • 10: 10 uS resolution: 0.01 mS .. 655.35 mS
  • 100: 100 uS resolution: 0.1 mS .. 6.5535 seconds
  • 1000: 1 mS resolution: 1 mS .. 65.535 seconds
  • other values should not be used!
       // initialize the stopwatch for 100 uS resolution
       // (only has to be done once, e.g. in APP_Init())
       MIOS32_STOPWATCH_Init(100);
       // reset stopwatch
       MIOS32_STOPWATCH_Reset();
       // execute function
       MyFunction();
       // send execution time via DEFAULT COM interface
       u32 delay = MIOS32_STOPWATCH_ValueGet();
       printf("Execution time of MyFunction: ");
       if( delay == 0xffffffff )
         printf("Overrun!\n\r");
       else
         printf("%d.%d mS\n\r", delay/10, delay%10);
    Note:
    : this function uses TIM4 on the STM32 chip
    Parameters:
    [in] resolution 1, 10, 100 or 1000
    Returns:
    < 0 on errors
         // reset stopwatch
         // execute function
         MyFunction();
         else
      Note:
      : this function uses TIM6 of the STM32 chip
      Parameters:
      Returns:
      < 0 on errors
      • 1000: NOT SUPPORTED FOR STM32F4!!!
           // reset stopwatch
           // execute function
           MyFunction();
           else
        Note:
        Parameters:
        Returns:
        < 0 on errors
s32 MIOS32_STOPWATCH_Reset ( void   )
Resets the stopwatch
Returns:
< 0 on errors
u32 MIOS32_STOPWATCH_ValueGet ( void   )
Returns current value of stopwatch
Returns:
1..65535: valid stopwatch value
0xffffffff: counter overrun
