MIOS32_UART_MIDI
Detailed Description
UART MIDI layer for MIOS32
Applications shouldn't call these functions directly, instead please use MIOS32_MIDI layer functions
Function Documentation
| s32 MIOS32_UART_MIDI_CheckAvailable |
u8 |
uart_port |
This function can be used to determine, if a UART interface is available
- Parameters:
| [in] | uart_port | UART number (0..2) |
- Returns:
- 1: interface available
0: interface not available
- Note:
- Applications shouldn't call this function directly, instead please use MIOS32_MIDI layer functions
| s32 MIOS32_UART_MIDI_Init |
u32 |
mode |
Initializes UART MIDI layer
- Parameters:
| [in] | mode | currently only mode 0 supported |
- Returns:
- < 0 if initialisation failed
- Note:
This function checks for a new package
- Parameters:
| [in] | uart_port | UART_MIDI module number (0..2) |
| [out] | package | pointer to MIDI package (received package will be put into the given variable |
- Returns:
- 0: no error
-1: no package in buffer
-10: incoming MIDI package timed out (incomplete package received)
- Note:
This function sends a new MIDI package to the selected UART_MIDI port (blocking function)
- Parameters:
| [in] | package | MIDI package |
- Returns:
- 0: no error
-1: UART_MIDI device not available
- Note:
- Parameters:
- Returns:
- 0: no error
-2: UART_MIDI buffer is full caller should retry until buffer is free again
- Note:
| s32 MIOS32_UART_MIDI_Periodic_mS |
void |
This function should be called periodically each mS to handle timeout and expire counters.
Not for use in an application - this function is called from MIOS32_MIDI_Periodic_mS(), which is called by a task in the programming model!
- Returns:
- < 0 on errors
| s32 MIOS32_UART_MIDI_RS_OptimisationGet |
u8 |
uart_port |
This function returns the running status optimisation enable/disable flag for the given MIDI OUT port.
- Parameters:
- Returns:
- -1 if port not available
0 if optimisation disabled
1 if optimisation enabled
- Note:
| s32 MIOS32_UART_MIDI_RS_OptimisationSet |
u8 |
uart_port, |
u8 |
enable | |
This function enables/disables running status optimisation for a given MIDI OUT port to improve bandwidth if MIDI events with the same status byte are sent back-to-back.
Note that the optimisation is enabled by default.
- Parameters:
| [in] | enable | 0=optimisation disabled, 1=optimisation enabled |
- Returns:
0 on success
- Note:
| s32 MIOS32_UART_MIDI_RS_Reset |
u8 |
uart_port |
This function resets the current running status, so that it will be sent again with the next MIDI Out package.
- Parameters:
- Returns:
< 0 on errors
- Note:
Variable Documentation
