Security alert. Local file inclusion bug. More info here, fixed release available. [18] (what's this?)
Do It Yourself (DIY)
The MidiBox community is very “do it yourself” oriented. Don't be offended by the phrase “do it yourself”, it isn't meant to be rude. Although it is there for good reason. The MidiBox community is all about building your own custom MIDI controller. While many parts are available as kits with the necessary components and printed circuit boards, MidiBox is not about simply buying a pre-built MIDI controller from someone else. The community will not build a MidiBox for money and does not tolerate soliciting to have one built for money.
do_it_yourself.txt · Last modified: 2008/03/16 03:15 (external edit)
Except where otherwise noted, content on this wiki is licensed under the following license:CC Attribution-Noncommercial-Share Alike 3.0 Unported
Recent changes RSS feed Donate Powered by PHP Valid XHTML 1.0 Valid CSS Driven by DokuWiki
