dougwellington_marquardt_switch_bulk_order
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
dougwellington_marquardt_switch_bulk_order [2008/10/22 15:58] – Doug Wellington | dougwellington_marquardt_switch_bulk_order [2008/12/27 22:58] – Phattline | ||
Line 1: | Line 1: | ||
====== Marquardt 6425 Series Switch Group Buy ====== | ====== Marquardt 6425 Series Switch Group Buy ====== | ||
- | This bulk order is for Marquardt 6425 series switches. | + | This bulk order is for Marquardt 6425 series switches. |
- | The switches should be no more than $1.50 (US Dollars), the caps with no LED holes will be no more than .30 each, and the caps with LED holes will be no more than $.50 each. My distributer has the switches and the no-LED caps in stock, but the caps with LED holes have an eight week lead time. Once the order is placed, I'll be able to put an " | + | Switches are available with an LED in the corner or without an LED. The switches with no LED are almost a dollar cheaper than the ones with the LED!!! |
+ | The switches should be no more than $1.50 (US Dollars), the caps with no LED holes will be no more than $.30 each, and the caps with LED holes will be no more than $.50 each. My distributer has the switches and the no-LED caps in stock, but the caps with LED holes have an eight week lead time. Once the order is placed, I'll be able to put an " | ||
Click on the "Edit this page" button (top left corner) and add your MIDIbox username and the number of switches and caps you would like. | Click on the "Edit this page" button (top left corner) and add your MIDIbox username and the number of switches and caps you would like. | ||
Line 15: | Line 17: | ||
|**Username**|**Switch Quantity**|**Cap (no LED) Quantity**|**Cap with LED Hole Quantity**| | |**Username**|**Switch Quantity**|**Cap (no LED) Quantity**|**Cap with LED Hole Quantity**| | ||
|Doug Wellington|64|48|16| | |Doug Wellington|64|48|16| | ||
- | |PHATTLINE|64|0|64| | + | |PHATTLINE|100|100|100| |
- | |**Total :** |**128**|**48**|**80**| | + | |moogah|100|84|16| |
+ | |boops|30|30|0|I am also Interestet with Printing on it " | ||
+ | |just phil|256|0|256| Also interested w/printing 1 to 8 [24x1, 24x2, 24x3.....24x8]| | ||
+ | |**Total :** |**514**|**162**|**352**| |
dougwellington_marquardt_switch_bulk_order.txt · Last modified: 2008/12/27 22:59 by Phattline
