how_to_mix_c_and_asm
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
how_to_mix_c_and_asm [2006/10/15 09:35] – (old revision restored) 127.0.0.1 | how_to_mix_c_and_asm [2008/09/29 12:27] (current) – wackazong | ||
Line 4: | Line 4: | ||
You might have to declare some additional variables, but the concept is quite straightforward. | You might have to declare some additional variables, but the concept is quite straightforward. | ||
+ | Do not forget to include the header file of your processor from the SDCC header files, or variables like PRODL will not be defined: e.g. #include < | ||
<code c> | <code c> | ||
- | unsigned char Scale_7bit(unsigned char evnt2, unsigned char min, unsigned char max) | + | unsigned char Scale_7bit(unsigned char evnt2, unsigned char min, unsigned char max) { |
// scaled value is (<8-bit random> * ) >> 8 | // scaled value is (<8-bit random> * ) >> 8 | ||
PRODL = evnt2 << 1; // 8bit value | PRODL = evnt2 << 1; // 8bit value | ||
Line 20: | Line 20: | ||
+ | Also, as well as the above example of ' |
how_to_mix_c_and_asm.1160904901.txt.gz · Last modified: 2007/04/07 02:47 (external edit)
