installing_gputils_and_sdcc_on_osx [2011/07/26 11:02] hanleynicholson |
installing_gputils_and_sdcc_on_osx [2023/11/26 20:16] admin |
Line 5: | Line 5: | ||
And more than that: you are able to [[how to use xcode2 as ide on a mac|use Apple's powerful Xcode as IDE]] and don't leave that except for sending the .syx file! You can even [[MIOS C Simulator - Debugger|debug your MIOS C-Applications]] - although this is in an early development state, please contribute code! //audiocommander.// | And more than that: you are able to [[how to use xcode2 as ide on a mac|use Apple's powerful Xcode as IDE]] and don't leave that except for sending the .syx file! You can even [[MIOS C Simulator - Debugger|debug your MIOS C-Applications]] - although this is in an early development state, please contribute code! //audiocommander.// | ||
- | The first step in this process is to install SDCC. If you have already SDCC running and calling "sdcc -v" in terminal gives you the info you're running 2.5. or higher, you have the most complicated step already completed! | + | The first step in this process is to install SDCC. If you have already SDCC running and calling "sdcc -v" in terminal should give you the info you're running 2.8.0. The usage of different versions isn't recommended as the MIOS Wrapper is very sensitive to the compiled code! |
Line 17: | Line 17: | ||
Now you have to type three commands: | Now you have to type three commands: | ||
- | * ./config | + | * ./configure |
* make | * make | ||
* make install | * make install | ||
sometimes you have to call these with "sudo", esp. "sudo make install". | sometimes you have to call these with "sudo", esp. "sudo make install". | ||
- | If you have problems compiling and installing SDCC, you might lack a library. | + | If you have problems compiling and installing SDCC 2.8.0, you might lack a library. |
Here is what you should have installed (in this particularly order) | Here is what you should have installed (in this particularly order) | ||
Line 32: | Line 32: | ||
==== Compiling for PIC18F4685? ==== | ==== Compiling for PIC18F4685? ==== | ||
- | If you want to compile for the PIC18F4685, you need a later version of GPUTILS than 0.13.4, at the moment you need to compile GPUTILS for yourself then. But it runs smoothly on OS X (tried on 10.5).\\ | + | If you want to compile for the PIC18F4685, you need a later version of GPUTILS than 0.13.4. The usage of 0.13.7 is highly recommended, newer versions may fail with SDCC 2.8.0.\\ |
**Following the instructions from [[http://gputils.sourceforge.net/|here]] we get:** | **Following the instructions from [[http://gputils.sourceforge.net/|here]] we get:** | ||
Line 74: | Line 74: | ||
</code> | </code> | ||
--- //[[Michael.Homscheidt@web.de|mhomscheidt]] 2009/01/06 11:14// | --- //[[Michael.Homscheidt@web.de|mhomscheidt]] 2009/01/06 11:14// | ||
+ | Update 2023-11-26: usage of SDCC 2.8.0 still mandatory, don't use newer versions which come with "port" or "brew"! - confirmed that the tool can also be compiled for Apple Silicon. Link to source code: https://sourceforge.net/projects/sdcc/files/sdcc/2.8.0/ | ||
Line 108: | Line 111: | ||
If you have trouble installing SDCC on your mac, post your questions/problems here: [[http://www.midibox.org/forum/index.php?topic=6527.0]] | If you have trouble installing SDCC on your mac, post your questions/problems here: [[http://www.midibox.org/forum/index.php?topic=6527.0]] | ||
- | [[http://cvresumewritingservices.org/|resume writing services]] | ||
