pedal_box:manual
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
pedal_box:manual [2009/12/15 05:47] – Durisian | pedal_box:manual [2009/12/15 05:52] – Durisian | ||
Line 82: | Line 82: | ||
* High Value | * High Value | ||
- | 2a. Static? \\ | + | 2a. Static? |
Each pedal can be set to 1 (static) or 0 (change with rig control patch change) \\ | Each pedal can be set to 1 (static) or 0 (change with rig control patch change) \\ | ||
- | Pedals will change the bankstick/ | + | Pedals will change the bankstick/ |
Line 444: | Line 444: | ||
^Function | ^Function | ||
- | |Channel | + | |Channel |
|Mode |N | |Mode |N | ||
- | |Note |Y | + | |Note |Y |
|Velocity | |Velocity | ||
- | |After Touch | + | |After Touch |
- | |Pitch Bend |N |N |N |N | | + | |Pitch Bend |Y |Y |Y |Y | |
- | |Control Change|Y | + | |Control Change|Y |
- | |Program Change|Y | + | |Program Change|Y |
- | Implementation is largly based on the Device Event List. Incoming events not listed will not be be responded too. | ||
The inbuilt MIDI merger if activated will forward all incoming events to the MIDI output (PbX and PbD) | The inbuilt MIDI merger if activated will forward all incoming events to the MIDI output (PbX and PbD) |
pedal_box/manual.txt · Last modified: 2009/12/15 05:52 by Durisian
