acsim_console_c
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
/* * ACSim_console.c * v 0.0.5 * * see header for version info and details */ // import standard I/O headers for console in- and output (printf and scanf) #import <stdio.h> // OS selection <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< SELECT YOUR OS HERE !!!! // You must choose one of the below options to set the correct Operating System for the application #define _DEBUG_OS_WIN //#define _DEBUG_OS_MAC #ifdef _DEBUG_OS_MAC #import <carbon/carbon.h> #endif // ACSim_mios.c contains all MIOS_FUNCTIONS() that are used throughout the program // eg MIOS_MIDI_AIN_PinGet(0) returns some random numbers in a range 0..127 // open up ACSim_mios.c to tweak around some values... // normally there should be no need to change the content of these files: #import "ACSim_mios.h" //#import "ACSim_mios.c" // toolbox, handy functions like random number generation, hex-output... #import "ACSim_toolbox.c" // import c files that are included in "main.h" //#include "../ACMidi.c" // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADD ADDITIONAL C.-FILES HERE!!!! // import main c source file #include "../main.c" // ***** RUNLOOP ***** void runloop(int loopcount) { _Bool continueRunloop = TRUE; char str[64] = ""; char choice = 'q'; unsigned char c = 0; unsigned int i; unsigned int pin = 0; unsigned int value = 0; unsigned int value2 = 0; // poll LCD_Display DISPLAY_Tick(); // debug info printf("\n\nMIOS.ACSim(%i) >> ", loopcount); // poll timer Timer(); // read input fgets(str, 32, stdin); // MAX chars = 32; this is NOT protected against buffer overflows!!! choice = str[0]; switch (choice) { case 'q': // quit case 'x': continueRunloop = FALSE; break; case ' ': // OK debug_din_value[DEBUG_BUTTON_OK] = 0; DIN_NotifyToggle(DEBUG_BUTTON_OK, debug_din_value[DEBUG_BUTTON_OK]); break; case '+': // ENC++ for(i=0;i<32;i++) { if(str[i]=='+') { c++; } } ENC_NotifyChange(DEBUG_ENCODER, c); break; case '-': // ENC -- for(i=0;i<32;i++) { if(str[i]=='-') { c--; } } ENC_NotifyChange(DEBUG_ENCODER, c); break; case 'a': // AIN... sscanf(str, "a%i,%i", &pin, &value); if((pin > DEBUG_AIN_NUM) || (value > 1023)) { printf("! max_pin=9, max_value=1023 !"); pin = 0; value = 0; } else { printf("scanning pin %i: %i", pin, value); // "set" pin values: debug_ain_value[pin] = value; AIN_NotifyChange(pin, value); } break; case 'd': // DIN... sscanf(str, "d%i,%i", &pin, &value); // invert value for easier rememberance value = value ^ 0x1; DIN_NotifyToggle(pin, value); break; case 'e': // ENC # ++/-- sscanf(str, "e%i", &pin); if(pin > DEBUG_ENC_NUM) { printf("! max_enc = %i", (DEBUG_ENC_NUM - 1)); return; } for(i=3;i<32;i++) { if(str[i]=='+') { c++; } else if(str[i]=='-') { c--; } } ENC_NotifyChange(pin, c); break; case 'j': // set jumper pin sscanf(str, "j%i", &pin); switch(pin) { case 10: PORTCbits.RC5 = 1; Timer(); PORTCbits.RC5 = 0; Timer(); break; case 14: PORTDbits.RD4 = 1; Timer(); PORTDbits.RD4 = 0; Timer(); break; default: printf("pin %i not (yet?) supported", pin); break; } break; case 'm': // MIDI Receive (m msgType, argA, argB) sscanf(str, "m%i,%i,%i", &pin, &value, &value2); MPROC_NotifyReceivedEvnt(pin,value,value2); break; case 'r': // random pin = ACRandomPin(); value = ACRandomInt(); printf("scanning pin %i: %i", pin, value); // "set" pin values: debug_ain_value[pin] = value; AIN_NotifyChange(pin, value); break; case 't': // test function sscanf(str, "t%i", &value); // for example: // IIC_SPEAKJET_Transmit14bit(value); // printf("\nDEC: %i \tPARAM3: %X \tPARAM2: %X \tPARAM1: %X", value, MIOS_PARAMETER3, MIOS_PARAMETER2, MIOS_PARAMETER1); break; default: // nothing... break; } if(continueRunloop) { runloop(++loopcount); } } // ***** MAIN ***** int main(int argc, char **argv) { int exit_code = 0; // manual: printf("\n++++++ MIOS-DEBUG-CONSOLE ++++++\n"); printf("(r)and (a)(pin),(value) (d)(pin),(state) \n"); printf("(e{opt.})(++)(-) (j)umper(pin) \n"); printf("(m)idi(msg),(argA),(argB) \n"); printf("(SPACE)OK e(x)it + [ENTER] \n\n"); // init debug srandomdev(); // set the random seed // init MIOS Init(); DISPLAY_Init(); Timer(); printf("\n"); // runloop runloop(0); return exit_code; }
acsim_console_c.1154464609.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
