acsim_console_c
This page is part of the mios_c_simulator_-_debugger
ACSim_console.h
ACSim_console.c
ACSim_toolbox.c
ACSim_mios.h
ACSim_mios.c
 *  ACSim_console.c
 *  v 0.0.5
 *  see header for version info and details
// import standard I/O headers for console in- and output (printf and scanf)
#import <stdio.h>
#ifdef _DEBUG_OS_MAC
	#import <carbon/carbon.h>
#endif
// ACSim_mios.c contains all MIOS_FUNCTIONS() that are used throughout the program
// eg MIOS_MIDI_AIN_PinGet(0) returns some random numbers in a range 0..127
// open up ACSim_mios.c to tweak around some values...
// normally there should be no need to change the content of these files:
#import "ACSim_mios.h"
//#import "ACSim_mios.c"
// toolbox, handy functions like random number generation, hex-output...
#import "ACSim_toolbox.c"
// import c files that are included in "main.h"
//#include "../ACMidi.c" // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADD ADDITIONAL C.-FILES HERE!!!!
// import main c source file
#include "../main.c"
// ***** RUNLOOP *****
void runloop(int loopcount) {
	_Bool continueRunloop = TRUE;
	char str[64] = "";
	char choice = 'q';
	unsigned char c = 0;
	unsigned int i;
	unsigned int pin = 0;
	unsigned int value = 0;
	unsigned int value2 = 0;
	// poll LCD_Display
	DISPLAY_Tick();
	// debug info
	printf("\n\nMIOS.ACSim(%i) >> ", loopcount);
	// poll timer
	Timer();
	// read input
	fgets(str, 32, stdin);	// MAX chars = 32; this is NOT protected against buffer overflows!!!
	choice = str[0];
	switch (choice) {
		case 'q': // quit
		case 'x':
			continueRunloop = FALSE;
			break;
		case ' ': // OK
			debug_din_value[DEBUG_BUTTON_OK] = 0;
			DIN_NotifyToggle(DEBUG_BUTTON_OK, debug_din_value[DEBUG_BUTTON_OK]);
			break;
		case '+': // ENC++
			for(i=0;i<32;i++) { if(str[i]=='+') { c++; } }
				ENC_NotifyChange(DEBUG_ENCODER, c);
			break;
		case '-': // ENC --
			for(i=0;i<32;i++) { if(str[i]=='-') { c--; } }
			break;
		case 'a': // AIN...
			sscanf(str, "a%i,%i", &pin, &value);
			if((pin > DEBUG_AIN_NUM) || (value > 1023)) {
				printf("! max_pin=9, max_value=1023 !");
				pin = 0; value = 0;
			} else {
				printf("scanning pin %i: %i", pin, value);
				// "set" pin values:
				debug_ain_value[pin] = value;
				AIN_NotifyChange(pin, value);
			break;
		case 'd': // DIN...
			sscanf(str, "d%i,%i", &pin, &value);
			// invert value for easier rememberance
			value = value ^ 0x1;
			DIN_NotifyToggle(pin, value);
			break;
		case 'e': // ENC # ++/--
			sscanf(str, "e%i", &pin);
			if(pin > DEBUG_ENC_NUM) {
				printf("! max_enc = %i", (DEBUG_ENC_NUM - 1));
				return;
			for(i=3;i<32;i++) {
				if(str[i]=='+') {
					c++;
				} else if(str[i]=='-') {
					c--;
			ENC_NotifyChange(pin, c);
			break;
		case 'j': // set jumper pin
			sscanf(str, "j%i", &pin);
			switch(pin) {
				case 10:
					PORTCbits.RC5 = 1;
					Timer();
					PORTCbits.RC5 = 0;
					Timer();
					break;
				case 14:
					PORTDbits.RD4 = 1;
					Timer();
					PORTDbits.RD4 = 0;
					Timer();
					break;
				default:
					printf("pin %i not (yet?) supported", pin);
					break;
			break;
		case 'm': // MIDI Receive (m msgType, argA, argB)
			sscanf(str, "m%i,%i,%i", &pin, &value, &value2);
			MPROC_NotifyReceivedEvnt(pin,value,value2);
			break;
		case 'r': // random
			pin = ACRandomPin();
			value = ACRandomInt();
			break;
		case 't': // test function
			sscanf(str, "t%i", &value);
//			for example:
//			IIC_SPEAKJET_Transmit14bit(value);
//			printf("\nDEC: %i \tPARAM3: %X \tPARAM2: %X \tPARAM1: %X", value, MIOS_PARAMETER3, MIOS_PARAMETER2, MIOS_PARAMETER1);
			break;
		default:
			// nothing...
			break;
	if(continueRunloop) {
		runloop(++loopcount);
// ***** MAIN *****
int main(int argc, char **argv) {
	int exit_code = 0;
	// manual:
	printf("\n++++++ MIOS-DEBUG-CONSOLE ++++++\n");
	printf("(r)and (a)(pin),(value) (d)(pin),(state) \n");
	printf("(e{opt.})(++)(-) (j)umper(pin) \n");
	printf("(m)idi(msg),(argA),(argB) \n");
	printf("(SPACE)OK e(x)it + [ENTER] \n\n");
	// init debug
	srandomdev(); // set the random seed
	// init MIOS
	Init();
	DISPLAY_Init();
	Timer();
	printf("\n");
	// runloop
	runloop(0);
	return exit_code;
acsim_console_c.1154465206.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
