ain_4_board_parts_list
AIN_4 module
This is a simple way of scaling CVs (as might come from a modular) ready for an STM322F4 Core module.
Schematic
The circuit is a very simple series of two inverting amplifiers per channel. The first is a TL072 powered from +12/-12V, while the second is an MCP6002 powered from 3v3/0V (ground). It's possible to preset the ranges (see below) but it's probably more useful to use the associated Control Board.
BOM
Type Qty Value Package PartsNotes
resistors
20 49k9 0204/7R1, R2, R4, R5, R6, R7, R8, R10, R11, R12, R13, R14, R16, R17, R18, R19, R20, R22, R23, R24
4 30k 0204/7R3, R9, R15, R21nominal gain can be adjusted e.g. (22k/49.9k)*5V = 2.2V
capacitors
410p025×050C1, C3, C5, C7
9100n025×050C10, C12, C13, C14, C15, C16, C17, C18, C20remove 1 if powering from Core
310uelectrolytic 2,5-6C9, C11, C19remove 1 if powering from Core
4optional025×050C2, C4, C6, C8can use another e.g. 10pF cap here for more filtering
inductors
2BEAD5MML1, L2
ICs
2MCP6002PDIL08IC2, IC4sockets are recommended
2TL072PDIL08IC1, IC3sockets are recommended
Vreg
1optionalTO-220VR1remove if powering from Core
headers
7 1X02_SMALLJP1, JP2, JP3, JP4, JP5, JP6, JP7check board for headers as SIL strips of 3, 5 or 6
8 1X03_SMALLJP8, JP9, JP10, JP11, JP12, JP13, JP14, JP15
2 2*5 (shrouded)J1, J2
Assembly
Resistors
Four 30k resistors as marked, the remainder are 49k9. For best results, match R1/R2, R7/R8 (and so on), and R4/R5/R6, R10/R11/R12 (and so on). The value is less important than the minimum deviation.
Capacitors
Four 10p as marked in pink, electrolytics in yellow, blue are optional. Remainder are 10n.
Power
Standard Eurorack header. Red = -12V, Blue = +12V, Green = 0V(ground). For Core power, bridge the yellow solder jumper, otherwise install the Vreg circuit in pink
Standalone use
For simplest results, use the complementary Control Board. Otherwise see below for header functions.
Five pin header
For scaling bipolar CVs, connect or switch into OFFSET (e.g. +5V)
For 0-5V operation, leave SWITCH open; for 0-10V operation, jumper or switch in SWITCH
Three pin header
With a 100k pot facing you, solder the left leg to 0V(ground) the centre to WIPER and the right to LEG. WIPER and LEG may be jumpered if pots aren't desired, but it is quite useful to have an attenuator to trim down variable CVs or even clip the second op amp for crunchy waveforms!
Interconnection to Core
J1 carries the scaled CV to J5A or J5B of an STM32F4 Core module.
License
ain_4_board_parts_list.1470844254.txt.gz · Last modified: 2016/08/10 15:50 by latigid_on
