bcd
Short for binary-coded decimal, a format for representing decimal numbers (integers) in which each digit is represented by four bits (nybble or nibble). See byte. For example, the number 375 would be represented as: 0011 0111 0101. One advantage of BCD over binary representations is that there is no limit to the size of a number. To add another digit, you just need to add a new 4-bit sequence. In contrast, numbers represented in binary format are generally limited to the largest number that can be represented by 8, 16, 32 or 64 bits.
bcd.1160904901.txt.gz ยท Last modified: 2007/11/17 18:18 (external edit)
