compiled_c_code_size [2006/11/14 13:15] |
compiled_c_code_size [2006/11/14 13:15] (current) |
Line 1: | Line 1: | ||
+ | From [[jackchaos]] via [[http://www.midibox.org/forum/index.php?topic=7959.0|Code Optimization]] | ||
+ | From I've been watching my code block size increase steadily as I work on my project and I'm now aware first hand of how assembler can be much more efficient that what a compiler can do. | ||
+ | I wanted to share a method I use to determine if my C optimizations are reducing the code size. | ||
+ | If you look inside the project.map file, at the top, look for the name of the function you're working on like this: | ||
+ | <code> | ||
+ | S_main__Update_LFO_LED_Status code 0x006304 program 0x0000fa | ||
+ | </code> | ||
+ | On the end is the size of the function in bytes: 0x0000fa = 250 bytes | ||
+ | Every time you compile your source, the project.map will update the starting address of the functions and show the bytes it uses. | ||
