====== Control Panel AIN_4 & AOUT_4 v1.2 ====== ===== AIN4 - AOUT4 v1.2 TOP ===== {{:phatline:Control-Top.jpg?800|}}\\ **BOM:**\\ [[https://www.taydaelectronics.com/electromechanical/switches-key-pad/push-button-switch-dc-30v-0-1a-dpdt-7x7mm.html|8x Switch better take mouser ones...]]\\ LED5-8: Normal LEDs\\ LED1-4: Bipolar LED comman Anode\\ VR1-4 AOUT4: 10K Lin\\ VR1-4 AIN4: 100K Lin\\ SKT1-4: 3,5 Stereo Jack?\\ JP21: Clock Input(if you have, then dont set G1_G5 on the backside) \\ J1: Gate/DOUT/Clock - Input - pinout see DOUTx4-Board\\ ===== AIN_4 v1.2 BACK ===== {{:phatline:Control-AOUT-back.jpg?800|}}\\ **BOM:**\\ RN1: 100k iso 652-4816P-1LF-100K\\ SJ 1-4: let them unsoldered\\ SJ 5-8: solder a 1K 0603 SMD Resistor from the Round PAD to 5V- to avoid Floating\\ Diodes: 1N4148 > only Stuff in AOUT4 Usecases\\ IC2: 74LV14H (SOIC14)\\ C2: 100nF Kerko\\ The Rest: cant remember...Resistors and Caps...\\ \\ about G5_G1, G2_G6, G4_G8, G7_G3:\\ J1 you connect to a DOUTx4 output, which deliver 8 DOUTs on 1 shroudet header\\ But we only use 4 DOUTs on the Controlboards... with this jumpers you decide which one!\\ IF you use a CLOCK coming from J21, then dont set G1_G5!\\ ===== Front-Panel for AIN_4 v1.2 ===== i measeured the PCB, and made a drawing in order to create a hand-drilled Frontpanel... so dont take the values as 100% true...:\\ {{:phatline:Control-Panel.jpg?800|}} {{ :phatline:Control-AOUT-seite.jpg?255|}} {{ :phatline:Control-AIN-AOUT-Panel-Label.jpg?500|}}
