====== dipBoardF4 ====== MIDIbox Hardware Platform extension for [[dipcoref4|dipCoreF4]]. ==== Features ==== * Very small size 65x46mm(less than your credit card). * Very low profile. * Your application board can be stacked on bottom with 'Micro-match' connectors. * The [[dipcoref4|dipCoreF4]] can be installed on the two side. * Provides all the most important features and ports as a regular mbhp. * Compatible with Andy's [[wcore_usb|USB]] and [[wcore_res-sd|RES-SD]] modules. \\ ==== Dimension ==== {{ :antichambre:1808_dipboard_v1.beta_docu_dim.png?600 |}} \\ ==== PCB ==== <WRAP group> <WRAP column 60%> {{ :antichambre:1809_dipBoardF4_v1.beta_top.png?500 |}} \\ {{ :antichambre:1809_dipBoardF4_v1.beta_bottom.png?500 |}} </WRAP> <WRAP column 35%> 2 layers PCB design.\\ Fits 2 layer mostly common design rules. * min. drill 10mil * min. width 6mil </WRAP>\\ </WRAP>\\ <WRAP column 60%> Top copper {{ :antichambre:1809_dipBoardF4_v1.beta_layer_top.png?500 |}} \\ Bottom {{ :antichambre:1809_dipBoardF4_v1.beta_layer_bottom.png?500 |}} </WRAP> \\ ---- ===== Ports and features. ===== <wrap todo>toDo</wrap> \\ ---- ===== Compatible/stack-able boards options ===== * [[m16|M16 Interface]], stack-able, to connect on a SPI port, provides 16 MIDI IO and 48 GPIO 8-) <wrap todo>toDo</wrap>
