All commons MIOS32 ports are available except:
Check the dipBoardF4 for more details
dipCoreF4 eagle lib for easy integration in your design. dipcoref4_v2a.zip
Check dipBoardF4 for more details about the connectors.
Due to the small SMD, which is sometime a difficulty to solder, the board is already assembled by manufacturer, except the connectors.
The mini-USB is optional.
Qty | Value | Package | Parts | Mouser | Reichelt | Conrad | LCSC | Notes |
Headers | ||||||||
3 | 1*20 | male | 437-3501012000006101 | No! | Adapted to sockets Mill-Max 0552-1-15-01-11-27-10-0 or 0553-1-15-15-11-27-10-0 | |||
Connnector | ||||||||
1 | mini-USB | THT | USB | 571-1734510-1 | no! | for other ref take care about restricted area! |
All dedicated MIDIBox Cores, must have pre-programmed bootloader in order to communicate in MIDI with MIOS-Studio
Like the Waveshare, the dipCoreF4 has no programmer onboard.
Even if the dipCoreF4 is now provided with it, should be necessary to explain connection and process.
You will need:
If you use a Disco or Nucleus board, those jumpers must be removed.
Once the dipCoreF4 is correctly connected refer to uCapps STM32F4 Based Core page > Installing the MIOS32 Bootloader where the flashing process is already well explained.
please use dedicated bootloader hex file
The 405RG is a TQFP64, a 10x10mm package and only 64 pins.
No Ethernet MAC and camera interface.
We use the same peripheral drivers same family, some compilation defined conditions were added for the specific pinout and type, number of ports.
toDo
For any questions, informations or observations do not hesitate to contact me (Forum).
Antichambre.
