dougwellington_marquardt_switch_bulk_order [2008/10/22 15:58] Doug Wellington |
dougwellington_marquardt_switch_bulk_order [2008/12/27 22:58] Phattline |
Line 1: | Line 1: | ||
====== Marquardt 6425 Series Switch Group Buy ====== | ====== Marquardt 6425 Series Switch Group Buy ====== | ||
- | This bulk order is for Marquardt 6425 series switches. These are the same switches that are used in the [[http://www.monolake.de/technology/monodeck_gallery.html|Monodeck II]]. You can see details of these switches at [[http://www.marquardt-switches.com/tact-and-key-switches.html|Marquardt Tact Switches Web Page]]. I ordered some samples of these switches - you can see some pictures at my [[http://www.midiboxaddict.com/parts|MIDIbox Addict Parts Page]]. I got pricing for the switches with an LED and without an LED. The switches with no LED are almost a dollar cheaper than the ones with the LED!!! LEDs are a lot cheaper than a buck, so I can't see buying the ones with the LED... (The switches themselves are identical.) | + | This bulk order is for Marquardt 6425 series switches. These are the same switches that are used in the [[http://www.monolake.de/technology/monodeck_gallery.html|Monodeck II]]. You can see details of these switches at [[http://www.marquardt-switches.com/tact-and-key-switches.html|Marquardt Tact Switches Web Page]]. I ordered some samples of these switches - you can see some pictures at my [[http://www.midiboxaddict.com/parts|MIDIbox Addict Parts Page]]. |
- | The switches should be no more than $1.50 (US Dollars), the caps with no LED holes will be no more than .30 each, and the caps with LED holes will be no more than $.50 each. My distributer has the switches and the no-LED caps in stock, but the caps with LED holes have an eight week lead time. Once the order is placed, I'll be able to put an "expedite" request in to see if we can get them faster... | + | Switches are available with an LED in the corner or without an LED. The switches with no LED are almost a dollar cheaper than the ones with the LED!!! LEDs are a lot cheaper than a buck, so I can't see buying the ones with the LED... (The switches themselves are identical.) Caps are available with and without holes for an LED. |
+ | The switches should be no more than $1.50 (US Dollars), the caps with no LED holes will be no more than $.30 each, and the caps with LED holes will be no more than $.50 each. My distributer has the switches and the no-LED caps in stock, but the caps with LED holes have an eight week lead time. Once the order is placed, I'll be able to put an "expedite" request in to see if we can get them faster... | ||
Click on the "Edit this page" button (top left corner) and add your MIDIbox username and the number of switches and caps you would like. | Click on the "Edit this page" button (top left corner) and add your MIDIbox username and the number of switches and caps you would like. | ||
Line 15: | Line 17: | ||
|**Username**|**Switch Quantity**|**Cap (no LED) Quantity**|**Cap with LED Hole Quantity**| | |**Username**|**Switch Quantity**|**Cap (no LED) Quantity**|**Cap with LED Hole Quantity**| | ||
|Doug Wellington|64|48|16| | |Doug Wellington|64|48|16| | ||
- | |PHATTLINE|64|0|64| | + | |PHATTLINE|100|100|100| I am also Interestet with Printing on it "1" to "8" (10x1, 10x2, 10x3.....10x8....rest normal) or "1" to "16"| |
- | |**Total :** |**128**|**48**|**80**| | + | |moogah|100|84|16| |
+ | |boops|30|30|0|I am also Interestet with Printing on it "1" to "16"| | ||
+ | |just phil|256|0|256| Also interested w/printing 1 to 8 [24x1, 24x2, 24x3.....24x8]| | ||
+ | |**Total :** |**514**|**162**|**352**| |
