You will find Here a List of Common Tools Used For Electronics DIY.
You don't absolutely need to have all of these things, but it sure helps!
Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :)
General / Safety
General
Workbench - Protect your house, have a proper work area
Storage Unit - Put your tools and components somewhere safe
Small Plastic Cup - Somewhere to put things temporarily. Don't leave your kit lying around.
Safety
Safety Glasses - Protect your sense of sight
Face mask - Protect your lungs
Fire Extinguisher - Don't let your soldering iron start a fire you can't put out
Fire Blanket - As above
Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm…. I think not.
Electrical Instruments
Multimeter - For testing circuitry. RS232 connected Autoranging DMM
Oscilloscope - For testing signals. Dual trace
Power Supply - Regulated lab power supply
Digital Camera - For taking snaps to share with other MIDIBoxers
Mini Torch - Let there be light. A AA Cell MagLight in your mouth means you get perfect light
Video Tutorials
Soldering Stuff
Soldering Iron or Station with Stand- Temperature controlled
Soldering Iron Tip Cleaner - Take care of your tools
Solder - Good quality solder for good quality joints, 63/37 Eutectic
Tinning Block - for taking care of soldering iron tips
PCB Holders - Make soldering easier and cleaner
Desoldering Braid - For removing chips from inferior boards, to insert in you MBHP ;)
Desoldering Pump - As above
Trimming and Fastening
Wire Strippers - For stripping insulation from cabling
Pliers Set - Various Sizes and types
Side Cutters - For trimming componenet leads
Screwdriver Set - Various sizes
Spanner Set - Various sizes, including shifter spanners
Socket Set - Various sizes
IC Puller - Little tool for pulling IC's from sockets
IC Placer - Little tool for putting IC's in sockets, spreads even pressure over all the pins
Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach
IDC Crimping Tool - Because doing it with pliers sucks
Electrical Tape - Too many uses to list
Misc
