electronics_diy_common_tools
DIY Common Tools for Electronics
You will find Here a List of Common Tools Used For Electronics DIY.
You don't absolutely need to have all of these things, but it sure helps!
Using a tool for purposes other than those for which it was designed can be just a little more difficult, or downright dangerous. Please be safe :)
General / Safety
General
  • Workbench - Protect your house, have a proper work area
  • Storage Unit - Put your tools and components somewhere safe
  • Small Plastic Cups - Somewhere to put things temporarily. Don't leave your kit lying around.
Safety
  • Safety Glasses - Protect your sense of sight
  • Face mask - Protect your lungs
  • Fire Extinguisher - Don't let your soldering iron start a fire you can't put out
  • Fire Blanket - As above
  • Soldering Smoke Absorber/Ventilator - MMmmm, Lead smoke. Mmmmm, Cancer. Mmmm, Insanity. Mmm…. I think not.
Electrical Instruments
  • Multimeter - For testing circuitry Voltages, Resistors and Transistors
  • Oscilloscope - For testing signals. Dual trace is better , allow signals comparison
  • Power Supply - Regulated lab power supply . Help in getting the right Voltages inputs
Video Tutorials
Soldering
  • Soldering Iron or Station with Stand- Temperature controlled
  • Solder - Good quality solder for good quality joints, 63/37 Eutectic
  • Desoldering Pump - - For removing soldered chips
  • Soldering Iron Tip Cleaner - Take care of your tools
  • Tinning Block - for taking care of soldering iron tips
  • PCB Holders - Make soldering easier and cleaner
Trimming and Fastening
  • Wire Strippers - For stripping insulation from cabling
  • Pliers Set - Various Sizes and types
  • Side Cutters - For trimming componenet leads
  • Screwdriver Set - Various sizes
  • Spanner Set - Various sizes, including shifter spanners
  • Socket Set - Various sizes
  • IC Puller - Little tool for pulling IC's from sockets
  • IC Placer - Little tool for putting IC's in sockets, spreads even pressure over all the pins
  • Claw - One of those little pens with a three-fingered claw for grabbing loose bits from where fingers can't reach
  • IDC Crimping Tool - Because doing it with pliers sucks
  • Electrical Tape - Too many uses to list
Misc
  • Mirror - Little mirror on a telescopic shaft for peeking where your eyes can't reach
  • Compressed Air Can - For cleaning stuff by blasting off dust
electronics_diy_common_tools.1468855549.txt.gz · Last modified: 2016/07/18 15:25 by psykhaze
