Bourns PEC11-series detented encoders
(From SmashTV)
Encoder mode: “DETENTED2”
Pinout: http://www.avishowtech.com/mbhp/images/encspecs17.gif
Note: the rightmost picture is “top down” (as seen from the top of the encoder looking down to the shaft)
pin “A” goes to D1 pin “C” goes to Vs pin “B” goes to D0 (This means that, encoder C pin is “common”. Encoder B pin goes to lower numbered DIN pin (of two pins assigned to that encoder) and encoder A pin to higher numbered DIN pin.)
the detent can be removed
Thanks go to:
mandingo: http://69.56.171.55/~midibox/forum/index.php?topic=3843.msg25094#msg25094 jdutcher: http://69.56.171.55/~midibox/forum/index.php?topic=3911.msg25766#msg25766 xcoulonx: http://69.56.171.55/~midibox/forum/index.php?topic=3299.msg23699#msg23699
Specs on VOTI (www.voti.nl) encoders;
M-SW-ROT, detented rotary encoder, price EUR 1,19
Encoder mode: “DETENTED2” (not 100% sure will verify later)
pinout; http://www.voti.nl/docs/rotary-encoder.jpg
if you view the encoder from the top with the pins pointing towards you;
left pin (A) goes to D0 middle pin (B) goes to D1 right pin (C) goes to Vs
the detent can also be removed
