Bourns PEC11-series detented encoders (From SmashTV)
Encoder mode: “DETENTED2”, 24 steps per turn
Pinout: http://www.avishowtech.com/mbhp/images/encspecs17.gif
Note: the rightmost picture is “top down” (as seen from the top of the encoder looking down to the shaft)
pin “A” goes to D1
pin “C” goes to Vs
pin “B” goes to D0
(This means that, encoder C pin is “common”. Encoder B pin goes to lower numbered DIN pin (of two pins assigned to that encoder) and encoder A pin to higher numbered DIN pin.)
the detent can be removed
Thanks go to:
mandingo: http://69.56.171.55/~midibox/forum/index.php?topic=3843.msg25094#msg25094
jdutcher: http://69.56.171.55/~midibox/forum/index.php?topic=3911.msg25766#msg25766
xcoulonx: http://69.56.171.55/~midibox/forum/index.php?topic=3299.msg23699#msg23699
Encoders from VOTI (www.voti.nl)
M-SW-ROT, detented rotary encoder
pinout: http://www.voti.nl/docs/rotary-encoder.jpg
if you view the encoder from the top with the pins pointing towards you;
left pin goes to D1 (highest numbered din pin)
middle pin goes to D0 (lowest numbered din pin)
right pin goes to Vs (ground)
the detent can also be removed
