encyclopedia
A
absorption
AC
active filter
ADC
Address Bus
AGC
AI
alphanumeric
AM
AMP
amperage
ampere
amplifier
amplitude
analog
anode
ANSI
antenna
Appletalk
array
array
ASCII
assembler
assembly language or assembler
astable
ATA
ATAPI
attenuation
AUI
AWG
Active Component
Aerial
AF (Audio Frequency)
ammeter
AND
B
backplane
bandwidth
base
battery
baud
BCD
BER
beta
bi-directional
binary
binary file
bios
biploar
bit
bitrate
blackout
board
Boolean
boot
bootstrap
BPS
brownout
BTU
buffer
bug
BUS
BUS cycle
BUS width
byte
bridge rectifier
Back Electromotive Force (back emf)
Bipolar Transistor
Bistable
Bottoming
Bridge
bypass capacitor
C
capacitance
capacitor
carrier sheet
Cat 5 or Category 5
cathode
CBR
CCD
CCD
CCTV
Celsius
Central Processing Unit
Centronics
charge
chassis
Chassis Ground
checksum
chip
chipset
choke
circuit
circuit board
circuit breaker
CISC
clock
clock rate
CMA
CMIL
CMOS
coax
coercivity
coil
cold start
collector
comparator
compile
compiler
compliant
component
conductor
contact
continuity
coulomb
CPLD
CPU (Central Processing Unit)
CRC
cross assembler
crosstalk
CRT
current
cutoff frequency
cycle
Cascade
Ceramic capacitor
complementary transistor
condenser
D
data
data rate
daughter board
dB
DB25
DB9
DC
debug
decibel
decimal
decrement
delta connection
Delta Transformer
demodulation
dielectric
differential amplifier
digital
digital signal
DIN
diode
DIP
DIP switch
DMA
driver
DSP
DSR
DTMF
DTR
duplex
darlington pair
diode drop
dipole
direct coupled amplifier
discrete
distortion
