======encyclopedia====== ===== A ===== [[absorption]]\\ [[AC]]\\ [[active filter]]\\ [[ADC]]\\ [[Address Bus]]\\ [[AGC]]\\ [[AI]]\\ [[alphanumeric]]\\ [[AM]]\\ [[AMP]]\\ [[amperage]]\\ [[ampere]]\\ [[amplifier]]\\ [[amplitude]]\\ [[analog]]\\ [[anode]]\\ [[ANSI]]\\ [[antenna]]\\ [[Appletalk]]\\ [[array]]\\ [[array]]\\ [[ASCII]]\\ [[assembler]]\\ [[assembly language or assembler]]\\ [[astable]]\\ [[ATA]]\\ [[ATAPI]]\\ [[attenuation]]\\ [[AUI]]\\ [[AWG]]\\ [[Active Component]]\\ [[Aerial]]\\ [[AF (Audio Frequency)]]\\ [[ammeter]]\\ [[AND]]\\ ===== B ===== [[backplane]]\\ [[bandwidth]]\\ [[base]]\\ [[battery]]\\ [[baud]]\\ [[BCD]]\\ [[BER]]\\ [[beta]]\\ [[bi-directional]]\\ [[binary]]\\ [[binary file]]\\ [[bios]]\\ [[biploar]]\\ [[bit]]\\ [[bitrate]]\\ [[blackout]]\\ [[board]]\\ [[Boolean]]\\ [[boot]]\\ [[bootstrap]]\\ [[BPS]]\\ [[brownout]]\\ [[BTU]]\\ [[buffer]]\\ [[bug]]\\ [[BUS]]\\ [[BUS cycle]]\\ [[BUS width]]\\ [[byte]]\\ [[bridge rectifier]]\\ [[Back Electromotive Force (back emf)]]\\ [[Bipolar Transistor]]\\ [[Bistable]]\\ [[Bottoming]]\\ [[Bridge]]\\ [[bypass capacitor]]\\ ===== C ===== [[capacitance]]\\ [[capacitor]]\\ [[carrier sheet]]\\ [[Cat 5 or Category 5]]\\ [[cathode]]\\ [[CBR]]\\ [[CCD]]\\ [[CCD]]\\ [[CCTV]]\\ [[Celsius]]\\ [[Central Processing Unit]]\\ [[Centronics]]\\ [[charge]]\\ [[chassis]]\\ [[Chassis Ground]]\\ [[checksum]]\\ [[chip]]\\ [[chipset]]\\ [[choke]]\\ [[circuit]]\\ [[circuit board]]\\ [[circuit breaker]]\\ [[CISC]]\\ [[clock]]\\ [[clock rate]]\\ [[CMA]]\\ [[CMIL]]\\ [[CMOS]]\\ [[coax]]\\ [[coercivity]]\\ [[coil]]\\ [[cold start]]\\ [[collector]]\\ [[comparator]]\\ [[compile]]\\ [[compiler]]\\ [[compliant]]\\ [[component]]\\ [[conductor]]\\ [[contact]]\\ [[continuity]]\\ [[coulomb]]\\ [[CPLD]]\\ [[CPU (Central Processing Unit)]]\\ [[CRC]]\\ [[cross assembler]]\\ [[crosstalk]]\\ [[CRT]]\\ [[current]]\\ [[cutoff frequency]]\\ [[cycle]]\\ [[Cascade]]\\ [[Ceramic capacitor]]\\ [[complementary transistor]]\\ [[condenser]]\\ ===== D ===== [[data]]\\ [[data rate]]\\ [[daughter board]]\\ [[dB]]\\ [[DB25]]\\ [[DB9]]\\ [[DC]]\\ [[debug]]\\ [[decibel]]\\ [[decimal]]\\ [[decrement]]\\ [[delta connection]]\\ [[Delta Transformer]]\\ [[demodulation]]\\ [[dielectric]]\\ [[differential amplifier]]\\ [[digital]]\\ [[digital signal]]\\ [[DIN]]\\ [[diode]]\\ [[DIP]]\\ [[DIP switch]]\\ [[DMA]]\\ [[driver]]\\ [[DSP]]\\ [[DSR]]\\ [[DTMF]]\\ [[DTR]]\\ [[duplex]]\\ [[darlington pair]]\\ [[diode drop]]\\ [[dipole]]\\ [[direct coupled amplifier]]\\ [[discrete]]\\ [[distortion]]\\ ===== T ===== [[terabyte]]\\ [[thermistor]]\\ [[thyristor]]\\ [[toggle]]\\ [[token]]\\ [[trace]]\\ [[transformer]]\\ [[transistor]]\\ [[transponder]]\\ [[trap]]\\ [[triac]]\\ [[tunneling]]\\ [[tweak]]\\ ===== U ===== [[UHV]]\\ [[UART]]\\ [[UDMA]]\\ [[UHF]]\\ [[UHV]]\\ [[UI]]\\ [[ultraviolet]]\\ [[UMID]]\\ [[Unicode]]\\ [[unipolar]]\\ [[USB]]\\ [[UV]]\\ ===== V ===== [[VA]]\\ [[vacuum tube]]\\ [[variable resistor]]\\ [[VHF]]\\ [[VMEbus]]\\ [[volt]]\\ [[voltage divider]]\\ [[VOM]]\\ [[VOX]]\\ ===== W ===== [[X10]]\\ [[watt]]\\ [[wavelength]]\\ [[wire]]\\ ===== X ===== [[X10]]\\ [[Xon/Xoff]]\\ [[XOR]]\\ ===== Y ===== [[yagi]]\\ ===== Z ===== [[Z]]\\ [[Z80]]\\ [[Zener]]\\ [[zeroing]]\\ [[zero wait state]]\\ [[zif]]\\
