Fadercore
Standard 220mm wide modules
VLR-8Enc
A PCB to add 8 Encoders with LED ring for each.
Eagle Files: https://github.com/novski/Midibox/tree/master/VLR-8Enc
BOM
BIll of Material
Qty Value Device Package 2 ML10 ML10 2 ULN2803SO18W SO18W 3 100n C-EU025-024×044 C025-024×044 6 100nF C-EU025-024×044 C025-024×044 6 10k 4306R SIL6 4 220 4816P-1SOIC16W SOIC16W 3 220 R-EU_0204/7 0204/7 3 74HC165N 74HC165NSO16D SO16D 3 74HC595 74HC595SO16D SO16D 8 BOURNS_PEL12T BOURNS_PEL12T_11-LED-RING PEL12T_11-LED-RING 3 TPIC6B595 TPIC6B595SO20W SO20W
Allways look for the cheapest seller, the Price may vary heavy!!! And look for Local dealers preferred. http://www.midibox.org/dokuwiki/doku.php?id=where_to_order_components
The Encoders
I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. Its not the cheapest but i sell them for a reasonable price.
The other Materials: Mouser
- 2x10pin Header, 517-30310-6002
- 1xResistor Array 220Ohm SMD,
- 1x74HC595 SMD,
- 2x100nF,
Project Order Basket on Mouser: fadercore_-_vlr-8enc
The PCB is available under: https://vlrlab.com/pcb/10-8-odisplay.html
