Fantoms PCBs
On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB.
Fatar keybed adapter
This is a adapter which is made for connect a FATAR keybed directly to the DIO-matrix without soldering. The rest should be self explaining.
Status: tested
Eagle *.brd: Fatar adapter
LED Ring
This is a LED ring which contains 15 LEDs arranged in a ring and the last LED as indication-led for the switch of an encoder. The LEDs are 0805 SMD type.
Status: untested
Eagle *.brd: not released yet
LED Bar
This is a LED bar which contains 13 LEDs arranged in a bar The LEDs are 0603 SMD type.
Status: tested
Eagle *.brd: LED Bar
4x Switchboard
This is a PCB for four marquardt 6425 switches, available with and without LEDs. In case you want to connect a DIO matrix to it, I added footprints for resistors but there are solder bridges too. In any case: Either solder the solder bridge or add a resistor to get the LEDs working. In case you only need two or three switches, you can simply cut it. I added two-pin-pinheader to every switch for connecting the LEDs.
Status: tested
Eagle *.brd: 4x Switchboard
8x Switchboard
SMD resistors and diodes are used here to use this board in a matrix. If you want to connect it directly to a DIN, just bridge the soldering pads of the diode… or add a diode…
Status: untested
Eagle *.brd: 8x Switchboard
