gm5x5x5_noob_guide
Building the GM5x5x5
Introduction
The GM5x5x5 is a midi interface for your computer. bla bla bla
Building Level
Noob guides have an difficulty indication from 1 to 5 where 1 is easy and 5 is hard to build. If you have never started a project before we urge you to start with a level 1 project first.
We indicate this project as Building level 3
Tools Needed
To start building your GM 5x5x5 board you will need some tools. Offcourse you could be creative and use whatever you like but this document is trying to be failsafe.
- Soldering Iron
- Soldering Flux
- Wire Cutter
- Beer
- etc put in pictures and so
Component List
The list is build up from components that should be solderd on the board in this order. However exeptions can be made. See building chapter for changes.
Diodes
Resistors
Sockets
Capacitors
Other
Building
The Chip
gm5x5x5_noob_guide.1235475823.txt.gz · Last modified: 2009/02/24 11:43 (external edit)
