home:project:misc:midi_mapper
THIS PAGE IS UNDER CONSTRUCTION !
Intro
This page will introduce the MIDI-Channel-Mapper device, which can route input channels from a single hardware input to output channels of a single hardware output in any way you want. Besides that, the device is designed to switch between channels of a selected bus (see doc) while performing, leaving the other buses untouched.
Features
List 'em
Skills / Equipment Required
Harware
What modules do I need?
List of parts
  • MBHP modules, ribbon connector cable & plugs
  • Lochplatine for buttons board & bankstick
  • Power input Buchse for Netzgerät
  • 2 MIDI-Buchsen for MIDI-in and MIDI-out
  • Quite a lot of Litzenkabel
  • Power-switch with backlight (optional)
  • 20 buttons with built-in LED's
  • Housing
  • 7-10V Netzgerät, > 700mA
Where to buy Parts
Connections
Connection diagrams - links if needed (create in you projects namespace
Enclosure / Case
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
Enclosure References
Software
Setting Up
PIC's must be setup with MIOS bootstrap Loader and MIOS before an application can be uploaded.
If you purchased you PIC from SmashTV or Mike's PCB Shop these will already installed.
We recommend you read the following before you continue:
Download
 links
Setup Instructions
 up to you
Extra
usage manual
+ anything else
home/project/misc/midi_mapper.1228117315.txt.gz · Last modified: 2008/12/01 07:41 by this
