home:project:midibox_sid
====== Overview ====== MIDIbox SID synthesizer is a project that uses the classic SID (Sound Interface Device) soundchip from the Commodore C64 personal computer under control of the Midibox as standalone Synthesizer. === Info on ucapps.de === * [[http://www.ucapps.de/midibox_sid.html|Overview]] <sup>uCApps</sup> * [[http://www.ucapps.de/midibox_sid_cs.html|Control Unit]] <sup>uCApps</sup> * [[http://www.ucapps.de/midibox_sid_csA.html|Step A]] | [[http://www.ucapps.de/midibox_sid_csB.html|B]] <sup>uCApps</sup> * [[http://www.ucapps.de/midibox_sid_walkthrough.html|Walkthrough]] <sup>uCApps</sup> * [[http://www.ucapps.de/howto_sid_wavetables_1.html|Wavetable Tutorial #1]] | [[http://www.ucapps.de/howto_sid_wavetables_2.html|#2]] <sup>uCApps</sup> * [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fdoc%2Fmbsidv2_parameter_chart.txt|MIDIbox SID V2 CC Parameter Chart]] <sup>uCApps</sup> === General info on the WIKI === * :!: [[MIDIbox SID FAQ|MIDIbox SID FAQ - Questions and Answers]] * [[MIDIbox SID TB303 mode]] * [[MIDIbox SID V1 Manual|The User Manual of MIDIbox SID V1]] * The [[SID module]] holds the SID chip. It connects to the [[core module]]. === HowTos ==== * mbSIDv2: **[[Adding two buttons for L/R SID selection instead of one]]** * mbSIDv2: **[[Changing the order of items in menu pages]]** * mbSIDv2: **[[Changing DIN pins]]** * mbSIDv2: **[[Changing DOUT pins]]** * mbSIDv2: **[[Layering the UI]]** * mbSIDv2: **[[Adding buttons for bankstick switching]]** * mbSIDv2: **[[Upgrade CS Step A (mbSIDv1) to have Shift function on Menu button]]** === External info === * [[http://www.danielprice.org.uk/synth-diy/sid_2.htm|PSU Photo Blog]] great photo blog about how to canibalize the C64 power supply for MIDIbox SID
home/project/midibox_sid.1239186706.txt.gz · Last modified: 2009/04/08 10:31 by /tilted/
