Next revision | Previous revision Last revision Both sides next revision | ||
how_to_mix_c_and_asm [2006/05/11 10:37] audiocommander created |
how_to_mix_c_and_asm [2008/09/10 17:31] audiocommander code plugin disappearance is killing me :/ |
Line 1: | Line 1: | ||
+ | It's actually quite easy! | ||
+ | As you can see in the example below, just enclose the ASM part with //_////_asm// and //_////_endasm;// | ||
+ | You might have to declare some additional variables, but the concept is quite straightforward. | ||
+ | <code c> | ||
+ | unsigned char Scale_7bit(unsigned char evnt2, unsigned char min, unsigned char max) { | ||
+ | // scaled value is (<8-bit random> * ) >> 8 | ||
+ | PRODL = evnt2 << 1; // 8bit value | ||
+ | PRODH = max-min+1; // range | ||
+ | __asm | ||
+ | movf _PRODL, W | ||
+ | mulwf _PRODH, 0 | ||
+ | __endasm; | ||
+ | return min + PRODH; | ||
+ | </code> | ||
+ | Also, as well as the above example of 'inline ASM', it is possible to include ASM code in .inc include files, and call that ASM code from within your C application. Please see the forum thread [[http://www.midibox.org/forum/index.php?topic=7698.0|using assembler in C - question about _ in front of macro names]] for more info. |
