how_to_use_midibox_cv_with_a_dout [2006/06/15 16:43] DrBunsen clean up english version grammar |
how_to_use_midibox_cv_with_a_dout [2009/05/06 14:23] (current) 129.120.95.63 |
Line 13: | Line 13: | ||
independent of the Note duration. | independent of the Note duration. | ||
- | Here as background is the trigger characteristic of some drum machines. The x0x-boxes (606,808,909...) trigger the sound at decrease of voltage at the gate instead of increase. (IE at the trailing edge of the +ve pulse rather than the leading edge - is that correct? this is known as S-Trig? - Bunsen) | + | Here as background is the trigger characteristic of some drum machines. The x0x-boxes (606,808,909...) trigger the sound at decrease of voltage at the gate instead of increase.\\ //IE at the trailing edge of the +ve pulse rather than the leading edge? I'm not sure if this is correct.\\ [[http://en.wikipedia.org/wiki/CV/Gate#Gate|Wikipedia]] says that Roland and Sequential gear is V-Trig {normal low, set high to trigger} and Moog, Korg and Yamaha is S-Trig {normal high, set low to trigger}. The [[http://66.102.7.104/search?q=cache:IBefydaCrJIJ:www.kentonuk.com/kmanualspdf/psoloman.pdf+%22V-trig%22+edge&hl=en&gl=au&ct=clnk&cd=5&client=firefox|manual]] for the Kenton Pro Solo MIDI-CV converter says: " ... Most synths / sequencers & drum machines will want the Positive edge pulse, but a few require the Negative edge instead. (e.g. Korg Monopoly) .. " I've also seen written elsewhere that the 606 trigger out is V-Trig, but the 707 internal triggering for it's own voices is S-Trig\\ Also, if the trailing edge was the trigger, how would gates and envelopes work ie ADSR when AD happens at leading edge, D as gate is held high, and R when gate drops low? - Bunsen// |
- | Activate dout: | + | __Activate dout:__ |
Download the source of Midibox CV at http://www.ucapps.de/mios_download.html and search for the following in | Download the source of Midibox CV at http://www.ucapps.de/mios_download.html and search for the following in | ||
Line 44: | Line 44: | ||
movlw 0x90 ; check for Note On at channel #1 | movlw 0x90 ; check for Note On at channel #1 | ||
- | IFNEQ MIOS_PARAMETER1, ACCESS, rgoto USER_MPROC_NRE_NoNoteChn1 | + | cpfseq MIOS_PARAMETER1, ACCESS |
+ | rgoto USER_MPROC_NRE_NoNoteChn1 | ||
USER_MPROC_NRE_NoteChn1 | USER_MPROC_NRE_NoteChn1 | ||
;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 | ;; MIOS_DOUT_PinSet expects pin number in WREG, value in MIOS_PARAMETER1 | ||
Line 70: | Line 71: | ||
activates the corresponding dout. A NoteOff deactivates the dout. | activates the corresponding dout. A NoteOff deactivates the dout. | ||
+ | __Define the number of connected DOUT shift registers:__ | ||
- | 1ms extension for Vintage Drummer: | + | If you're using more than one DOUT shift register, you must also change this code in "main.inc" to reflect the number of shift registers: |
+ | <code> | ||
+ | ;; initialize the SRIO driver | ||
+ | movlw 0x01 | ||
+ | call MIOS_SRIO_NumberSet | ||
+ | </code> | ||
+ | To set it to the maximum (16), just replace the code with this: | ||
+ | <code> | ||
+ | movlw 0x0F | ||
+ | </code> | ||
+ | __1ms Extension For Vintage Drum Machines:__ | ||
- | Those who want to trigger Vintage Drummer have to modify the sourcecode as follows: | + | Those who want to trigger vintage drums have to modify the sourcecode as follows: |
Search for the following: | Search for the following: | ||
<code> | <code> | ||
Line 101: | Line 118: | ||
with a 1ms latency. | with a 1ms latency. | ||
- | (Would it be possible to instead have the DOUT pins held normally high, and drop to 0v on NoteOn? That way there should be no latency. - Bunsen) | + | MIDIbox SEQ allows up to 48 digital outputs as this type of trigger. [[http://ucapps.de/midibox_seq_options.html]] |
+ | __Changing the midi channel:__ | ||
+ | If you want the DOUT triggers to respond to MIDI events on a channel other than #1, replace instances of "0x80" and "0x90" with the following values: | ||
+ | * Channel 1: 0x80, 0x90 | ||
+ | * Channel 2: 0x81, 0x91 | ||
+ | * Channel 3: 0x82, 0x92 | ||
+ | * Channel 4: 0x83, 0x93 | ||
+ | * Channel 5: 0x84, 0x94 | ||
+ | * Channel 6: 0x85, 0x95 | ||
+ | * Channel 7: 0x86, 0x96 | ||
+ | * Channel 8: 0x87, 0x97 | ||
+ | * Channel 9: 0x88, 0x98 | ||
+ | * Channel 10: 0x89, 0x99 | ||
+ | * Channel 11: 0x8A, 0x9A | ||
+ | * Channel 12: 0x8B, 0x9B | ||
+ | * Channel 13: 0x8C, 0x9C | ||
+ | * Channel 14: 0x8D, 0x9D | ||
+ | * Channel 15: 0x8E, 0x9E | ||
+ | * Channel 16: 0x8F, 0x9F | ||
+ | __Forum articles:__ | ||
- | Forum articles: | + | [[http://www.midibox.org/forum/index.php/topic,13478.0.html]] -- Information on receiving on ALL channels, information on excluding specific DOUT pins from being reset with the 1ms trigger extension code |
- | http://www.midibox.org/forum/index.php?topic=2701.0\\ | + | [[http://www.midibox.org/forum/index.php?topic=2701.0]] (German)\\ |
- | http://www.midibox.org/forum/index.php?topic=6333.0 | + | [[http://www.midibox.org/forum/index.php?topic=6333.0]] (German) |
