how_to_use_xcode2_as_ide_on_a_mac [2008/01/04 15:05] audiocommander updated for Xcode3 |
how_to_use_xcode2_as_ide_on_a_mac [2011/07/22 14:51] digineural removed spam |
Line 92: | Line 92: | ||
PATH=/usr/local/bin:$PATH | PATH=/usr/local/bin:$PATH | ||
- | cd $SRCROOT/tools/mkmk.pl "$SRCROOT/MAKEFILE.SPEC" | + | cd $SRCROOT/tools |
+ | ./mkmk.pl "$SRCROOT/MAKEFILE.SPEC" | ||
echo Makefile replaced. | echo Makefile replaced. | ||
exit 0 | exit 0 | ||
+ | </code> | ||
+ | If you get an error like "line x: ./mkmk.pl: Permission denied", you need to give the perl script execute rights. Easiest way to do this is open your favorite FTP program and set "Executeable" or use the Terminal: | ||
+ | <code> | ||
+ | chmod 750 <drag mkmk.pl in terminal window, path should appear) | ||
</code> | </code> | ||
Line 123: | Line 129: | ||
+ | For XCode 3.0 (under Leopard) do not forget to remove the quotes around the $SRCROOT (the variable points to your project directory). | ||
As you see, the only trick is, to invoke the makefile. | As you see, the only trick is, to invoke the makefile. | ||
Line 149: | Line 157: | ||
If you have questions, feel free to post them here: http://www.midibox.org/forum/index.php?topic=6527.0 | If you have questions, feel free to post them here: http://www.midibox.org/forum/index.php?topic=6527.0 | ||
