====== Integrated Circuit ====== {{ ::neonking:pdip_40_t.jpg?direct&200 |}} ===== Introduction ===== An Integrated Circuit is a formal name for a component commonly termed chip or IC, that is a small electronic device made out of a semiconductor material. The first integrated circuit was developed in the 1950s by Jack Kilby of Texas Instruments and Robert Noyce of Fairchild Semiconductor, now a part of Schlumberger. Integrated circuits are used for a variety of devices, including microprocessors (CPUs), audio and video equipment, and automobiles. Integrated circuits are often classified by the number of transistors and other electronic components they contain:\\ * **SSI** (small-scale integration): Up to 100 electronic components per chip\\ * **MSI** (medium-scale integration): From 100 to 3,000 electronic components per chip\\ * **LSI** (large-scale integration): From 3,000 to 100,000 electronic components per chip\\ * **VLSI** (very large-scale integration): From 100,000 to 1,000,000 electronic components per chip\\ * **ULSI** (ultra large-scale integration): More than 1 million electronic components per chip\\ IC are usually packaged in a plastic or ceramic case with external connector pins. ===== MIDIbox-related ICs ===== ^ Description ^Type ^Mouser Ref ^Reichelt ref^ Digikey ref^ |74HC165 |Serial Register |595-CD74HC165EE4 | | | |74HC595 |Serial Register |595-CD74HC595E | | | |74HCT541 |Line Driver |595-D74HCT541E | | | |74HC00 |Logic Gate |595-CD74HC00EE4 | | | |6N138 |OptoCoupler |512-6N138M | | | |MOS4051 |Multiplexer switch |595-CD74HC4051M96 | | | |TL072 |Operational Amplifier |595-TL072ACP | | | |TL074 |Operational Amplifier |512-LM324N | | | |MCP6004 |Operational Amplifier |579-MCP6004-E/P | | | |MCP3208 |Analog>Digital converter|579-MCP3208CIP | | | |MCP3428 |Analog>Digital converter|579-MCP3428E/SL | | | |MAX525 |Digital>Analog converter|700-MAX525BCPP | | | |CD22M3494EZ |Crosspoint switch |968-CD22M3494EZ | | | ==== Datasheets ==== * [[http://www.mouser.com/ds/2/405/cd74hc595-406651.pdf|74HC595]] * [[http://www.mouser.com/ds/2/405/cd74hc165-441105.pdf|74HC165]] *
