ju_control_roland_alpha_juno_control_panel_cs
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
ju_control_roland_alpha_juno_control_panel_cs [2012/09/05 19:55]
lemonhorse
ju_control_roland_alpha_juno_control_panel_cs [2017/09/19 12:14]
lemonhorse [MIDIBox Juno Control (JuCtrl)]
Line 1: Line 1:
 ====== MIDIBox Juno Control (JuCtrl) ====== ====== MIDIBox Juno Control (JuCtrl) ======
-{{http://www.subfrequenz.net/​visuals/​albums/​userpics/10001/​20120316MidiboxJuCTRL002.jpg}}+{{https://www.subf.net/​visuals/​albums/​import_pool/2017Archiv2/​20120316MidiboxJuCTRL002.jpg}}
 ====== Project Description ====== ====== Project Description ======
-The **MIDIBox JuCtrl** is a **Alpha Juno** MIDI Controller [[https://​en.wikipedia.org/​wiki/​Roland_Alpha_Juno]]. It's an additional **control surface** and MIDI Controller for the Roland Alpha Juno Synthesizer. I started this Project because the original Juno User CS is very minimalistic (80s Style). With the **MIDIbox JuCtrl** is every Tone parameter directly at hand. Furthermore you can store all 128 Juno Tone Colours on Bankstick.+The **MIDIBox JuCtrl** is a **Alpha Juno** MIDI Controller [[https://​en.wikipedia.org/​wiki/​Roland_Alpha_Juno]]. It's an additional **control surface** and MIDI Controller for the Roland Alpha Juno Synthesizer. I started this Project because the original Juno User CS is very minimalistic (80s Style). With the **MIDIbox JuCtrl** is every Tone parameter directly at hand. Furthermore you can store all 128 Juno Tone Colours on one Banksticks (1024 Juno Tones with 8 Banksticks).
Line 23: Line 23:
   * 3x MBHP DINx4 | => ([[http://​www.ucapps.de/​mbhp_din.html]])   * 3x MBHP DINx4 | => ([[http://​www.ucapps.de/​mbhp_din.html]])
   * 1x MBHP IIC MIDI Module (extra MIDI IO for Juno Synth) IIC MIDI adr. = 0x10(J3 port) | =>​([[http://​www.ucapps.de/​mbhp_iic_midi.html]])   * 1x MBHP IIC MIDI Module (extra MIDI IO for Juno Synth) IIC MIDI adr. = 0x10(J3 port) | =>​([[http://​www.ucapps.de/​mbhp_iic_midi.html]])
-  * 1-8x Bankstick | Store 128 Juno Tones [24256(32k)] =>​([[http://​www.ucapps.de/​mbhp_bankstick.html]])+  * 1-8x Bankstick | Store 128-1024 Juno Tones [24256(32k)] =>​([[http://​www.ucapps.de/​mbhp_bankstick.html]])
Line 31: Line 31:
   * Ju Control MBHP DIN & DOUT | => {{:​juctrl:​juctrldindout.pdf|}} (08/2012)   * Ju Control MBHP DIN & DOUT | => {{:​juctrl:​juctrldindout.pdf|}} (08/2012)
   * JuCtrl Juno MIDI IO dataflow (overview) | => {{:​juctrl:​juctrldataflowoverview.pdf|}} (08/2012)   * JuCtrl Juno MIDI IO dataflow (overview) | => {{:​juctrl:​juctrldataflowoverview.pdf|}} (08/2012)
 +====== CC MIDI ======
 +|MIDI CC 001 - MODULATION WHEEL                                   |
 +|MIDI CC 002 - DCO ENV MODE                                       |
 +|MIDI CC 003 - VCF ENV MODE                                       |
 +|MIDI CC 004 - FOOD CONTROL ​                                      |
 +|MIDI CC 005 - PORTAMENTO TIME (REAL CC)                          |
 +|MIDI CC 006 - VCA ENV MODE                                       |
 +|MIDI CC 007 - VOLUME (REAL CC)                                   |
 +|MIDI CC 008 - DCO WAVEFORM Pulse (0..3) ​                         |
 +|MIDI CC 009 - DCO WAVEFORM Saw  (0..5) ​                          |
 +|MIDI CC 010 - DCO SUB WAVEFORM ​ (0..5) ​                          |
 +|MIDI CC 011 - DCO Range (0=4', 1=8', 2=16', 3=32'​) ​              |
 +|MIDI CC 012 - DCO Sub Osc Level (0..3) ​                          |
 +|MIDI CC 013 - DCO Noise Level   ​(0..3) ​                          |
 +|MIDI CC 014 - HPF Cutoff (0...3) ​                                |
 +|MIDI CC 015 - Chorus Switch (0=Off, 1=On)                        |
 +|MIDI CC 016 - DCO LFO Modulation (0..7F) ​                        |
 +|MIDI CC 017 - DCO Envelope Pitch Modulation Depth (0..7F) ​       |
 +|MIDI CC 018 - DCO Aftertouch Modulation Sensitivity (0..7F) ​     |
 +|MIDI CC 019 - DCO WAVE 3 PULSE WITH (0..7F) ​                     |
 +|MIDI CC 020 - DCO WAV3 PWM Rate (0..7F) ​                         |
 +|MIDI CC 021 - VCF Cutoff (0..7F) ​                                |
 +|MIDI CC 022 - VCF Resonance (0..7F) ​                             |
 +|MIDI CC 023 - VCF LFO Modulation Depth (0..7F) ​                  |
 +|MIDI CC 024 - VCF ENV Modulation Depth (0..7F) ​                  |
 +|MIDI CC 025 - VCF Key Follower (0..F) ​                           |
 +|MIDI CC 026 - VCF Aftertouch (0..F) ​                             |
 +|MIDI CC 027 - VCA Level (0..7F) ​                                 |
 +|MIDI CC 028 - VCA Aftertouch Sesitivity (00..0F) ​                |
 +|MIDI CC 029 - LFO Rate (0..7F) ​                                  |
 +|MIDI CC 030 - LFO Delay (0..7F) ​                                 |
 +|MIDI CC 031 - ENV T1 - Attack Time   ​(0..7F) ​                    |
 +|MIDI CC 032 - ENV L1 - Attack Level  (0..7F) ​                    |
 +|MIDI CC 033 - ENV T2 - Break Time    (0..7F) ​                    |
 +|MIDI CC 034 - ENV L2 - Break Level   ​(0..7F) ​                    |
 +|MIDI CC 035 - ENV T3 - Decay Time    (0..7F) ​                    |
 +|MIDI CC 036 - ENV L3 - Sustain Level (0..7F) ​                    |
 +|MIDI CC 037 - ENV T4 - Release Time                              |
 +|MIDI CC 038 - ENV Key Follower (0..0F) ​                          |
 +|MIDI CC 039 - Chorus Rate (0..7F) ​                               |
 +|MIDI CC 040 - DCO Bender Range (0..C) ​                           |
 +|MIDI CC 041                                                      |
 +|MIDI CC 042                                                      |
 +|MIDI CC 043                                                      |
 +|MIDI CC 044                                                      |
 +|MIDI CC 045                                                      |
 +|MIDI CC 046                                                      |
 +|MIDI CC 047                                                      |
 +|MIDI CC 048                                                      |
 +|MIDI CC 049                                                      |
 +|MIDI CC 050                                                      |
 +|MIDI CC 051                                                      |
 +|MIDI CC 052                                                      |
 +|MIDI CC 053                                                      |
 +|MIDI CC 054                                                      |
 +|MIDI CC 055                                                      |
 +|MIDI CC 056                                                      |
 +|MIDI CC 057                                                      |
 +|MIDI CC 058                                                      |
 +|MIDI CC 059                                                      |
 +|MIDI CC 060                                                      |
 +|MIDI CC 061                                                      |
 +|MIDI CC 062                                                      |
 +|MIDI CC 063                                                      |
 +|MIDI CC 064 - Hold ON/OFF (REAL CC)                              |
 +|MIDI CC 065 - Portamento ON/OFF (REAL CC)                        |
 +|MIDI CC 066                                                      |
 +|MIDI CC 067                                                      |
 +|MIDI CC 068                                                      |
 +|MIDI CC 069                                                      |
 +|MIDI CC 070                                                      |
 +|MIDI CC 071                                                      |
 +|MIDI CC 072                                                      |
 +|MIDI CC 073                                                      |
 +|MIDI CC 074                                                      |
 +|MIDI CC 075                                                      |
 +|MIDI CC 076                                                      |
 +|MIDI CC 077                                                      |
 +|MIDI CC 078                                                      |
 +|MIDI CC 079                                                      |
 +|MIDI CC 080                                                      |
 +|MIDI CC 081                                                      |
 +|MIDI CC 082                                                      |
 +|MIDI CC 083                                                      |
 +|MIDI CC 084                                                      |
 +|MIDI CC 085                                                      |
 +|MIDI CC 086                                                      |
 +|MIDI CC 087                                                      |
 +|MIDI CC 088                                                      |
 +|MIDI CC 089                                                      |
 +|MIDI CC 090                                                      |
 +|MIDI CC 091                                                      |
 +|MIDI CC 092                                                      |
 +|MIDI CC 093                                                      |
 +|MIDI CC 094                                                      |
 +|MIDI CC 095                                                      |
 +|MIDI CC 096                                                      |
 +|MIDI CC 097                                                      |
 +|MIDI CC 098                                                      |
 +|MIDI CC 099                                                      |
 +|MIDI CC 100                                                      |
 +|MIDI CC 101                                                      |
 +|MIDI CC 102                                                      |
 +|MIDI CC 103                                                      |
 +|MIDI CC 104                                                      |
 +|MIDI CC 105                                                      |
 +|MIDI CC 106                                                      |
 +|MIDI CC 107                                                      |
 +|MIDI CC 108                                                      |
 +|MIDI CC 109                                                      |
 +|MIDI CC 110                                                      |
 +|MIDI CC 111                                                      |
 +|MIDI CC 112                                                      |
 +|MIDI CC 113                                                      |
 +|MIDI CC 114                                                      |
 +|MIDI CC 115                                                      |
 +|MIDI CC 116                                                      |
 +|MIDI CC 117                                                      |
 +|MIDI CC 118                                                      |
 +|MIDI CC 119                                                      |
 +|MIDI CC 120                                                      |
 +|MIDI CC 121                                                      |
 +|MIDI CC 122 - Local ON/OFF (REAL CC)                             |
 +|MIDI CC 123 - ALL NOTES OFF(REAL CC)                             |
 +|MIDI CC 124 - OMNI OFF     (REAL CC)                             |
 +|MIDI CC 125 - OMNI ON      (REAL CC)                             |
 +|MIDI CC 126 - MONO ON      (REAL CC)                             |
 +|MIDI CC 127 - POLY ON      (REAL CC)                             |
 ====== Notes ====== ====== Notes ======
Line 207: Line 338:
 ====== Project Status ====== ====== Project Status ======
-09/2012+12/2012
Line 223: Line 354:
   || --- 100% ENVELOPE functions (BTN F1-F4)   || --- 100% ENVELOPE functions (BTN F1-F4)
   || --- 100% Send Bankstick sysex-dump (Tone Backup)   || --- 100% Send Bankstick sysex-dump (Tone Backup)
 +  || --- V1.000 (09/2012)
 +  || --- V1.001 (12/​2012) ​
 +  || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. ​
 +  ||            The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001
 +  ||            Note: The Juno Keyboard does NOT have the Aftertouch function itself. But with another Keyboard or Sequencer ​
 +  ||            connected (to JuCtrl MIDI IN) You can use all the nice Aftertouch Effects of the Roland Alpha Juno.
Line 229: Line 367:
 ====== Software ====== ====== Software ======
-  * [[http://​www.subf.net/​midibox/​JuCtrl/​JuCtrlV100018F4620.zip]] (09/2012)+  * [[http://​www.subf.net/​midibox/​JuCtrl/​JuCtrlV100018F4620.zip]] (Outdated|09/2012)
 +  * [[http://​www.subf.net/​midibox/​JuCtrl/​JuCtrlV1001PIC18F6420.zip]] (12/2012)
 ====== Links ====== ====== Links ======
ju_control_roland_alpha_juno_control_panel_cs.txt · Last modified: 2017/09/19 12:14 by lemonhorse
