This is a raw version of the HowTo - don't let that scare you though :D
FILE: app_defines.h
* find a free spot in the ram like
;; free: 0x6d..0x79
* add the variable to store the layer
CS_MENU_LAYER EQU 0x06d ; stores the active layer
* and possibly change the comment to match the new situation
;; free: 0x6e..0x79
FILE: setup_*.asm:
* in the CS_MENU_DIN_TABLE add the new buttons (SR + Pin might not match)
DIN_ENTRY CS_MENU_BUTTON_Layer1, 2, 7 DIN_ENTRY CS_MENU_BUTTON_Layer2, 1, 4 DIN_ENTRY CS_MENU_BUTTON_Layer3, 1, 5 DIN_ENTRY CS_MENU_BUTTON_Layer4, 1, 6 DIN_ENTRY CS_MENU_BUTTON_Layer5, 1, 7 DIN_ENTRY CS_MENU_BUTTON_Layer6, 1, 3
* in the CS_MENU_DOUT_TABLE add the layer LEDs (SR + Pin might not match)
DOUT_ENTRY TMP3, 0, 1, 0 ; Layer 1 LED DOUT_ENTRY TMP3, 1, 1, 1 ; Layer 2 LED DOUT_ENTRY TMP3, 2, 1, 2 ; Layer 3 LED DOUT_ENTRY TMP3, 3, 1, 3 ; Layer 4 LED DOUT_ENTRY TMP3, 4, 1, 4 ; Layer 5 LED DOUT_ENTRY TMP3, 5, 1, 5 ; Layer 6 LED
FILE: cs_menu_buttons.inc:
* after
;; -------------------------------------------------------------------------- ;; the button functions are defined here ;; --------------------------------------------------------------------------
* add the button handlers for the layer buttons
CS_MENU_BUTTON_Layer1 CS_MENU_BUTTON_Layer2 CS_MENU_BUTTON_Layer3 CS_MENU_BUTTON_Layer4 CS_MENU_BUTTON_Layer5 CS_MENU_BUTTON_Layer6
* now it should compile and run, but not do anything
* each of those “functions” handles the button presses for one layer button
* For example, the “Oscillator Layer” handler
CS_MENU_BUTTON_Layer2 ;; OSC 1 Layer
;; do nothing if button has been depressed btfsc MIOS_PARAMETER2, 0 ;; check if button has been released return ;; if so exit ;; open the menu call CS_MENU_GetMenuID_OSC ;; goto OSC menu page call CS_MENU_BUTTON_Hlp_MenuChangeOk ;; propagate menu change ;; store the active layer movlw 0x02 ;; put 2 (layer number) on the WREG movwf CS_MENU_LAYER ;; and write it to the variable return ;; done
* if you only use the predefined menus, this is all there is to do for each layer. * I added a special menu for Filter and LFO, this requires some more work:
FILE: cs_menu_tables.inc:
* in CS_MENU_TABLES_IDS add another row like this:
db CS_MENU_L_FL, CS_MENU_ROOT, CS_MENU_ROOT, CS_MENU_ROOT
* CS_MENU_L_FL is the new [F]ilter+[L]fo menu * in CS_MENU_TABLES_L add a new row like this:
CS_MENU_T_ENTRY CS_MENU_TABLE_L_FL, CS_MENU_Page_Parameters, CS_MENU_EXEC_GoToRoot, "F/L", 0, 0x00, PRINT_NOP
* right after that table there's a list of the menu IDs. To add our new menu add a line like this:
CS_MENU_L_FL EQU 0x0f
* now we want to add the menu to the menu structure. To do so you need to find CS_MENU_TABLE_L_ROOT, the “root table” * I wanted to have the new menu between the LFO and Envelope menus, so I put it between those two:
CS_MENU_ENTRY CS_MENU_L_LFO, "LFO", 0x000, PRINT_NOP, EXEC_MENU, R2PP2R_NOP CS_MENU_ENTRY CS_MENU_L_ENV, "ENV", 0x000, PRINT_NOP, EXEC_MENU, R2PP2R_NOP
* resulting in this:
CS_MENU_ENTRY CS_MENU_L_LFO, "LFO", 0x000, PRINT_NOP, EXEC_MENU, R2PP2R_NOP CS_MENU_ENTRY CS_MENU_L_FL, "F/L", 0x000, PRINT_NOP, EXEC_MENU, R2PP2R_NOP CS_MENU_ENTRY CS_MENU_L_ENV, "ENV", 0x000, PRINT_NOP, EXEC_MENU, R2PP2R_NOP
* note that you can change the order of the menu items as you wish. * Now we're still missing the actual menu :D * At the end of the file insert something like this:
; The combined FIL/LFO menu ;
CS_MENU_TABLE_L_FL
db (CS_MENU_TABLE_L_FL_End-CS_MENU_TABLE_L_FL)/CS_MENU_ENTRY_LEN, 0x00
;; Register (00=dummy) |<->| max print ix exec ix parameter transfer CS_MENU_ENTRY SID_Ix_L_Fx_CUTOFF_L, "Cut", 0xfff, PRINT_Fx_CUTOFF, EXEC_SELPAR, R2PP2R_Fx_CUTOFF CS_MENU_ENTRY SID_Ix_L_Fx_RESONANCE, "Res", 0x0ff, PRINT_Fx_RESON, EXEC_SELPAR, R2PP2R_Fx_RESON CS_MENU_ENTRY 0x00, " ", 0x000, PRINT_NOP, EXEC_NOP, R2PP2R_NOP CS_MENU_ENTRY SID_Ix_LFOx_RATE, "Rte", 0x0ff, PRINT_LFOx_RATE, EXEC_SELPAR, R2PP2R_LFOx CS_MENU_ENTRY SID_Ix_LFOx_DEPTH, "Dep", 0x0ff, PRINT_LFOx_PMDEC8,EXEC_SELPAR, R2PP2R_LFOx
* this menu page has 5 entries, the third one being an empty dummy entry
* Now the menu is done
* to make one layer button open this menu all we need to do is change the handler above to call this page
* in this case that would look like this:
CS_MENU_BUTTON_Layer5 ;; FILTER/LFO LAYER
;; do nothing if button has been depressed btfsc MIOS_PARAMETER2, 0 return movlw 0x10 movwf CS_MENU_LAYER call CS_MENU_GetMenuID_FL ; goto FILTER/LFO menu page goto CS_MENU_BUTTON_Hlp_MenuChange return
One last thing to edit
The CS_MENU_GetMenuID_FL function, which returns the ID of the menu page needs to be defined. This should be done in cs_menu.inc in the section titled
;; -------------------------------------------------------------------------- ;; This function returns the CS_MENU_x_xxx ID depending on selected engine ;; --------------------------------------------------------------------------
which is around line 2056.
