lre-oled-bar [2022/01/13 03:09] phatline [LRE8x2 096 SSD1306-BAR for Eurorack] |
lre-oled-bar [2022/02/04 14:22] phatline [To Do] |
Line 2: | Line 2: | ||
{{:phatline:LRE-OLED-BAR-3D-Perspektive.jpg?600|}}\\ | {{:phatline:LRE-OLED-BAR-3D-Perspektive.jpg?600|}}\\ | ||
{{:phatline:Frontpanel-massen.jpg?900|}}\\ | {{:phatline:Frontpanel-massen.jpg?900|}}\\ | ||
+ | **I made this PCBs to use it with Fairlightii´s [[mb-lre8x2cs_pcb]]**\\ | ||
**4x PCBs on one 100x100mm**\\ | **4x PCBs on one 100x100mm**\\ | ||
Line 9: | Line 11: | ||
With this Method you pay for 20 PCBs 8€ all inclusive to EU-Austria\\ | With this Method you pay for 20 PCBs 8€ all inclusive to EU-Austria\\ | ||
So you can Stuff 5 LRE8x2 with this.\\ | So you can Stuff 5 LRE8x2 with this.\\ | ||
+ | Here are the gerberfiles for production - i made it with[[https://jlcpcb.com/|JLCPCB]]\\ | ||
+ | {{:phatline:LRE-OLED-RevA-Gerber.zip?900|}}\\ | ||
+ | {{:phatline:JLCPCB-low-cost.jpg?476|}}\\ | ||
+ | And they are working, they also V-Grooved on my marking without extra costs...\\ | ||
+ | My next Revision would be a Micromatch header on the left side of the pcbs so i can directly interconnect to a Display Driver (crimping instead of soldering)\\ | ||
====== Hardware Requirements ====== | ====== Hardware Requirements ====== | ||
- | * [[CV1]] or other MIOS32 Cores\\ | + | * a MIOS32 Core to connect too\\ |
* Soldering Iron - with a Dip that can Handle Thruhole-Parts, solder Paste...\\ | * Soldering Iron - with a Dip that can Handle Thruhole-Parts, solder Paste...\\ | ||
- | * dont forget the Micromatch connectors, and Ribbon cables\\ | + | * LRE8x2 for its nature use\\ |
====== Shematic ====== | ====== Shematic ====== | ||
{{:phatline:LRE-OLED-BAR-Shematic.jpg?400|}}\\ | {{:phatline:LRE-OLED-BAR-Shematic.jpg?400|}}\\ | ||
- | Full Shematic:\\ | + | **Full**: {{:phatline:LRE-OLED-BAR-Shematic.pdf?800|}}\\ |
- | {{:phatline:LRE-OLED-BAR-Shematic.pdf?800|}}\\ | + | |
- | ====== Building ====== | + | ====== Building and BOM====== |
- | There are 1Row 7Pin headers (2.54mm pitch) on the Backside of the PCB\\ | + | The Values are printet on the PCB. |
- | The Values are printet on the PCB. Following Quantity is for 4 PCBs:\\ | + | |
+ | **Following Quantity is for 4 PCBs:**\\ | ||
+ | 8x 1Row 7Pin headers (2.54mm pitch)\\ | ||
8x 1K 1208 SMD Resistors\\ | 8x 1K 1208 SMD Resistors\\ | ||
12x 10uF 1208 Capacitors (non polarized)\\ | 12x 10uF 1208 Capacitors (non polarized)\\ | ||
- | 8x 0.96" SSD1306 Screens\\ | ||
3x 10K 0603 SMD Resistors which are optional\\ | 3x 10K 0603 SMD Resistors which are optional\\ | ||
{{:phatline:LRE-OLED-BAR-3D-Back.jpg?700|}}\\ | {{:phatline:LRE-OLED-BAR-3D-Back.jpg?700|}}\\ | ||
- | On the Frontside you put in the Screens | + | 8x 0.96" SSD1306 Screens\\ |
{{:phatline:LRE-OLED-BAR-3D-Front.jpg?700|}}\\ | {{:phatline:LRE-OLED-BAR-3D-Front.jpg?700|}}\\ | ||
- | ===== BOM LCSC===== | + | ====== Frontpanel====== |
- | these are the parts which must be handsoldered\\ | + | {{:phatline:Frontpanel.jpg?700|}}\\ |
- | ^Comment^Designator^Footprint^LCSC Part Number^Lot^ | + | I made a DXF File which you can send to [[https://www.formulor.de/|Formulor in Germany]]\\ |
- | |ULN2003ADRW|Q1-Q3|SOIC-18_300mil|C9683|3| | + | |
- | |PEC11R-4015F-S24|ENC1-ENC5|tht|C143789|5| | + | |
- | |Micromatch-2x5|LCDi1,LCDo1,Ji89,Jo89|tht|C590954|4| | + | |
- | |Switch|S1|tht|C273513|1| | + | |
- | **S1 can be stuffed with:** Matias, CherryMX, MEC-3FTH9, TL1265\\ | + | |
+ | i panalized it so there are 2 Plates in it\\ | ||
+ | I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ | ||
- | ===== BOM AliExpress===== | + | The Version with the not needet 3mm Mounting holes for the LRE8x2:{{:phatline:2xLRE-OLED-BAR-DXF.zip?700|}}\\ |
- | [[https://de.aliexpress.com/item/32831561142.html?spm=a2g0s.9042311.0.0.27424c4dzZbi5A|2xSSD1306-7Pin]] | + | |
+ | My Orginal Autocad Drawing, + DXFs for Fabrication without the non needet Mounting Holes:{{:phatline:EURO-LRE-Frontpanel.zip?700|}}\\ | ||
- | ===== BOM LCSC===== | ||
- | these are the parts which are presoldered by the Pick and Place Machine\\ | ||
- | ^Comment^Designator^Footprint^LCSC Part Number^ | ||
- | |47uF|C1,C2|1206|C96123| | ||
- | |100nF|C3,C4,C7,C8|0805|C49678| | ||
- | |10uF|C5,C6|1206|C13585| | ||
- | |LED-Yellow|Da1,Db1,Dc1,Dd1,De1-Da19,Db19,Dc19,Dd19,De19|0603|C72038| | ||
- | |180|R1-R5|0603|C22828| | ||
- | |1K|R6,R7|1206|C4410| | ||
- | |10k|R8-R25|0603|C25804| | ||
- | |74HC595|U1-U3|SOIC-16|C5947| | ||
- | |74HC165|U4,U5|SOIC-16|C5613| | ||
- | + Ribbon Cables for example (MOUSER):\\ | + | **Recommend Material from Formulor:**\\ |
- | 710-63911015521CAB|1\\ | + | 3mm Acrylglas GS 384x384mm, mittelgrau transparent(7C83)\\ |
- | ===== PART Locations===== | ||
- | {{:phatline:LRE5-LCD2-PCP-Parts.png?500|}}\\ | ||
====== To Do ====== | ====== To Do ====== | ||
- | making Revision 2, because in 1 the Transistor-Array-Fottprint is wrong and had to bridged\\ | + | The LRE-OLED-Bar & The Frontpanel are a Part of my [[MSQ-CC-LRE-V2]]\\ |
- | {{:phatline:LRE5-LCD2-Proto-Bridges.jpg?500|}}\\ | + | so look there for more information.... |
====== Community users working on it ====== | ====== Community users working on it ====== | ||
* **[[Phatline]]** = PCB & Shematic, UI-Programming, Documentation...\\ | * **[[Phatline]]** = PCB & Shematic, UI-Programming, Documentation...\\ | ||
Just let a Private message on the forum to user already involved.\\ | Just let a Private message on the forum to user already involved.\\ |
