mb-606re
MB-606RE
Introduction
The MB-606RE is a re-edit of CYM/HH and BD/SD drum parts of the Roland TR-606 to be controlled via MIDI (midibox MB-Modulbox) or CV through analog-Sequencers , in a a Eurorack-designed panel.
Well known Circuit Mods from around Web & time are included by default.
FrontPanel
606 BD+SD, 606 HH+CY
To spare Space: we sandwich in 2 layers
- 1st PCB : BD+SD UI-PCB / HH+CY UI-PCB »> Breakoutboard+Potentiometer Boards
- 2nd PCB : Analog Circuits: 2n We get the Analog Circuits mounted 90° angled with vertical female socket and angled DIL Pinheaders for better heat dissipation
Sandwich view - Analog Boards
Original Schematics
BD / SD
CY / HH
Mods
Mod Sources
Analog Mods
- HH Noise: 10K or 50K lin or log,have to check , orginally 10K trimpot, only change volume not to absolutely silence.
- 6OSC-Gain: 50K log (not sure)
- CY-HH Ext: 50K lin
- CY-HH BPF-Resonance: 100K Stereo lin
- CY-HH BPF1: 5K lin
- CY-HH BPF2: 5K lin
- CY-HPF: : 50K log
- HH-HPF:50K log
- OH Decay: 1M lin
- CH Decay: 1M lin
- CY Decay: 2M lin (internet) Phats machine has a 4M log
- BD Tune: 50K Log
- BD Decay: 2M lin
- BD Tone: 100K lin
- Noise: 50K log
- SD Snappy: 100K lin
- SD Decay: 500K lin
- SD Tune: 1M lin
On-Going
1. UI Parts Listing
Frontpanel
Value | Type | Qty |
3.5mm Jack | Vertical PCB-Mount | 13 |
Switch | SPDT Vertical PCB-Mount ON-OFF-ON | 1 |
Pots / Knobs
5K | Linear | 2 |
10K | Linear | 6 |
50K | Linear | 6 |
50K | Logarithmic | 6 |
100K | Linear | 2 |
1M | Linear | 3 |
2M? | Linear | 2 |
Knobs | Soft/Plastic/Alu | 31 |
2. BD/SD - CYM/HH Parts Listing
Modded BD
Value | Type | Qty | Original Designation |
2SA733/BC547 | Transistor | 1 | Q15 |
2SC945/BC557 | Transistor | 2 | Q14,Q20 |
JRC2904/LM2904 | OpAmp | 1 | IC5 |
50KΩ | Pot Log | 2 | Level, ModTune |
100KΩ | Pot Linear | 1 | ModTone |
2MΩ | Pot Linear | 1 | ModDecay |
0,47µF/50V | Capa Elec | 1 | C25 |
1µF/50V | Capa Elec | 1 | C22 |
33µF/16V | Capa Elec | 1 | C19 |
47µF/16V | Capa Elec | 1 | C18 |
0,015µF | Capa Ceram | 2 | C23,C24 |
0,01µF | Capa Ceram | 1 | C21 |
1KΩ | Res 1/4W | 1 | R64 |
3,3KΩ | Res 1/4W | 1 | R58 |
4,7KΩ | Res 1/4W | 1 | R62 |
6,8KΩ | Res 1/4W | 1 | R122 |
10KΩ | Res 1/4W | 5 | R52,R56Mod/R67/R68/R93 |
22KΩ | Res 1/4W | 2 | R51,R69 |
33KΩ | Res 1/4W | 1 | R92 |
47KΩ | Res 1/4W | 3 | R59,R65,R94 |
100KΩ | Res 1/4W | 1 | R57 |
470KΩ | Res 1/4W | 1 | R56 |
560KΩ | Res 1/4W | 1 | R61 |
Modded Noise/SD
2SA733/BC547 | Transistor | 1 | Q18 |
2SC945/BC557 | Transistor | 6 | Q19,Q17,Q16,Q30,Q31,Q32 |
JRC4558/NJM4558D | OpAmp | 1 | IC10 |
50KΩ | Pot Log | 2 | Level,Noise |
100KΩ | Pot Linear | 1 | ModSnappy |
500KΩ | Pot Linear | 1 | ModDecay |
1MΩ | Pot Linear | 1 | ModTune |
1N4148 | Diode | 2 | D26,D27 |
22pF | Capa Ceram | 1 | C36Mod |
0,001µF | Capa Ceram | 1 | C97 |
0,0015µF | Capa Ceram | 1 | C38 |
0,0018µF | Capa Ceram | 2 | C52,C58 |
0,0033µF | Capa Ceram | 1 | C34 |
0,01µF | Capa Ceram | 1 | C57 |
0,027µF | Capa Ceram | 2 | C32,C33 |
0,047µF | Capa Ceram | 1 | C51 |
0,055µF | Capa Ceram | 1 | C37 |
2,2µF | Capa Ceram | 1 | C35Mod |
0,47µF/50V | Capa Elec | 2 | C31,C35 |
1µF/50V | Capa Elec | 2 | C30,C53 |
47µF/16V | Capa Elec | 2 | C28,C54 |
100Ω | Res 1/4W | 2 | R146,R151 |
330Ω | Res 1/4W | 2 | R107,R153 |
680Ω | Res 1/4W | 1 | R115 |
1KΩ | Res 1/4W | 2 | R99,R100 |
2,2KΩ | Res 1/4W | 1 | R91Mod |
4,7KΩ | Res 1/4W | 1 | R97 |
5,6KΩ | Res 1/4W | 1 | RDecayMod |
10KΩ | Res 1/4W | 5 | R95,R96,R98,R102,R111 |
15KΩ | Res 1/4W | 1 | R121 |
18KΩ | Res 1/4W | 1 | R104 |
22KΩ | Res 1/4W | 2 | R113,R154 |
27KΩ | Res 1/4W | 2 | R105,R120 |
47KΩ | Res 1/4W | 2 | R114,R118 |
68KΩ | Res 1/4W | 2 | R110,R148 |
100KΩ | Res 1/4W | 4 | R101,R106,R152,R155 |
470KΩ | Res 1/4W | 1 | R112Mod |
680KΩ | Res 1/4W | 1 | R119 |
1MΩ | Res 1/4W | 3 | R116,R147,R150 |
Modded CY
Modded HH
3.MB-Modulbox-Main2-PCB > 4xAOUT_LC + 8xTrigger In PCB Parts Listing
Integrate CV Scaling circuit
4.Footprints List
- ALPS Pots
- Alpha Pots
- 3,5mm Jack
- Switch
5. Schematics in KiCAD
KiCad Pre-Project MAIN by Phatline » shematics have to be overworked
- Analog drums PCBs
- UI PCBs
- Special MB-Modulbox-Main2 PCB (4xAOUT-LC+8xTrigger out)
mb-606re.1470065646.txt.gz · Last modified: 2016/08/01 15:34 by psykhaze
