===== BULK ORDER MB-LRE8x2CS rev 4.6 ===== The time-frame of the bulk order is not still well defined but it should take place in april/may of 2014. You will find the technical informations about the MB-LRE8x2CS rev 4.6 PCB [[http://www.midibox.org/dokuwiki/doku.php?id=mb-lre8x2cs_rev4.6|here]]. I need to know also how much is the interest for: * MB-LR4x2CS_RED: 4x2 LEDrings board already populated by (128x) 1206 red SMD LEDs but without encoders footprint, * MB-LR4x2CS_BLUE: 4x2 LEDrings board already populated by (128x) 1206 blue SMD LEDs but without encoders footprint, * MB-E4x2CS: 4x2 Encoders board, MB-LR4x2CS and MB-E4x2CS can be stacked one on the other. * 20mm shaft undetended 16mm encoder, typically to use with //MB-LRE8x2CS//, * 25mm shaft undetended 16mm encoder, typically to use with //MB-E4x2CS//. |**MB-E4x2CS**| |{{http://jeromebo.free.fr/Wiki/MB-LRE8x2CS_Rev4.6/MB-E4x2CS_Rev1.3.png?800 |MB-E4x2CS}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_71654.jpg?800 |MB-E4x2CS_top}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_15485.jpg?800 |MB-E4x2CS_bottom}}| |**MB-LR4x2CS**| |{{http://jeromebo.free.fr/Wiki/MB-LRE8x2CS_Rev4.6/MB-LR4x2CS_Rev2.2.png?800 |MB-LR4x2CS}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_238197.jpg?800 |MB-LR4x2CS_top}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_50149.jpg?800 |MB-LR4x2CS_bottom}}| |**MB-LR4x2CS + MB-E4x2CS**| |{{http://midibox.org/forums/uploads/gallery_7662_237_82513.jpg?800 |2_boards_stacked}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_109590.jpg?800 |2_boards_stacked}}| |{{http://midibox.org/forums/uploads/gallery_7662_237_12970.jpg?800 |2_boards_stacked}}| |**Encoders**| |{{http://jeromebo.free.fr/Wiki/MB-LRE8x2CS_Rev4.6/Encoders.png?400 |Encoders}}| Notes: * MB-LR4x2CS consists of improved DOUTx3 modules and 8 SMD LEDrings. There is 8 holes (D=10mm) to let pass the shaft of the encoders toward. * MB-E4x2CS: consists of DINx2 modules and 8 encoders. I added also as option a DOUTx2 chain, the footprint for 16 LEDs and 16 tact switches ([[http://de.mouser.com/ProductDetail/E-Switch/TL1100F160Q/?qs=7Bi7Dg8SEnw0f0sbwKIXZA==|E-Switch TL1100]] / [[http://de.mouser.com/ProductDetail/Omron-Electronics/B3F-4000/?qs=B3tblJ0Nlt8c5sbFRctxww==|OMRON B3F-40XX]]) onto the board so you can use it __standalone__ with 16 switches or a mix of //n// x encoders + //(16-2n)// x switches (4 encoders + 8 switches e.g.) with for each switch the LED feedback. * EDIT: I added also the footprint for the [[http://www2.mouser.com/search/refine.aspx?Ntk=P_MarCom&Ntt=152889006|6425 MARQUARDT]] switch (with LED). * MB-LR4x2CS and MB-E4x2CS have the same size: 6,716 x 3,025 inch (170,5864 x 76,835 mm) and their mounting holes match together. * All the encoders are undetended and have a rational life of 100,000 cycles (...good quality). ==== Price list ==== <del>All the price below are indicative. They will be definitive when the bulk order will start.</del> <del>//The accuracy of all this prices is enough good except for MB-LR4x2CS (because of the numbers of parameters to take in count).//</del> ^ ^ MB-LRE8x2CS ^ MB-LR4x2CS ^ MB-LR4x2CS ^ MB-E4x2CS ^ ^units^ Rev 4.6 ^ RED ^ BLUE ^ ^ |>100| <del>11€</del> | <del>13,50>17,50€</del> | <del>13,50>17,50€</del> | <del>7€</del> | |>150| <del>10€</del> | <del>13>17€</del> | <del>13>17€</del> | <del>6,50€</del> | |>200| <del>9,75€</del> | <del>12,75>16,75€</del> | <del>12,75>16,75€</del> | <del>6,25€</del> | |Notes| | LEDs included | LEDs included | | ------------------------------------------------------------------------ **EDIT**: New prices (16/04/2014) ^ ^ MB-LRE8x2CS ^ MB-LR4x2CS ^ MB-LR4x2CS ^ MB-E4x2CS ^ ^units^ Rev 4.6 ^ RED ^ BLUE ^ ^ |>50| 11€ | 14,50€ | 15€ | 7€ | |>100| 10€ | 12€ | 12,50€ | 6,25€ | |>150| 9,50€ | 11€ | 11,50€ | 5,75€ | |>200| 9€ | || 5,50€ | |Notes| | LEDs included & soldered || | ------------------------------------------------------------------------ ^ ^ 16mm encoder ^ 16mm encoder ^ Price ^ ^units^ Shaft=20mm ^ Shaft=25mm ^ /unit ^ |>1500| 15,50€ | 15,50€ | 0,62€ | |>2000| 14€ | 14€ | 0,56€ | |>3000| 13,50€ | 13,50€ | 0,54€ | |Notes| By 25 units | By 25 units | | ==== Waitinglist ==== You can already fill your Username in the list below. It is not an engagement but for me to estimate the amount of people interested and the number of boards/encoders and the shipping material that I will have to order. - Log into the Wiki (create an account if any), - Click on the "Edit this page" button ("pencil" symbol in the top right corner of this page), - Add your __MIDIbox Forum username__ and the number of PCBs and encoders (multiple of 25) you would like, - Don't forget to __update the quantities__ to the end of the list. Use your full and **correct FORUM (not the wiki) name**, so I can reach you via PM or email. //Do not edit anything else on this page (except to correct my English or spelling mistakes!).// ^:::^ **MB-LRE8x2CS** ^ **MB-LR4x2CS** ^ **MB-LR4x2CS** ^ **MB-E4x2CS** ^ **16mm encoder** ^ **16mm encoder** ^ ^:::^ **Rev 4.6** ^ **RED** ^ **BLUE** ^ ^ **Shaft=20mm** ^ **Shaft=25mm** ^ |**Username**|:::|:::|:::|:::| //(multiple of 25)// | //(multiple of 25)// | |Fairlightiii| 20 | 8 | 6 | 20 | 50 | 75 | |ken| 1 | 1 | 1 | 2 | 0 | 0 | |monokinetic | 0 | 2 | 0 | 2 | 0 | 25 | |eptheca | 0 | 2 | 0 | 2 | 25 | 0 | |=FFW=> | 6 | 4 | 0 | 14 | 100 | 0 | |Dangerz | 2 | 3 | 3 | 6 | 25 | 25 | |Highcooley | 0 | 4 | 2 | 8 | 0 | 50 | |crunchie | 2 | 0 | 0 | 0 | 50 | 0 | |Imp | 0 | 1 | 0 | 1 | 0 | 0 | |m00dawg | 1 | 0 | 0 | 0 | 25 | 0 | | StormB| 1 | 0 | 0 | 0 | 25 | 0 | |norbim1| 0 | 2 | 0 | 2 | 0 | 25 | |Shuriken| 2 | 2 | 0 | 4 | 25 | 25 | |Protosx | 4 | 0 | 0 | 0 | 0 | 75 | |bugfight | 4 | 4 | 0 | 4 | 100 | 0 | |smidirin | 2 | 0 | 0 | 0 | 0 | 0 | |DubplateDerek| 0 | 4 | 0 | 4 | 0 | 50 | |Tr1ptron1c | 1 | 2 | 2 | 4 | 0 | 25 | |jobi | 1 | 1 | 1 | 2 | 0 | 25 | |fabcoulon | 8 | 0 | 0 | 0 | 0 | 0 | |Zossen | 0 | 0 | 2 | 2 | 0 | 25 | | | | | | | | | | | | | | | | | | | | | | | | | |**Total :** | **55** | **40** | **17** | **77** | **425** | **425** | **Jérôme** aka **Fairlightiii.** -----I tried to be clear but if I made a mistake or if I forgot something, don't hesitate to say it in the [[http://midibox.org/forums/topic/18618-mb-lre8x2cs-rev-46-bulk-order-spring-2014/ |forum]].-----
