mb_rgb-led_matrix_8x8
MIDIbox RGB-LED Matrix 8x8
The RGB LED matrix described here can be used to signal feedback to the user, as for example in my MIDI Matrix with 56 Inputs and 56 Outputs. But, it can also be used for fancy stuff, Vegas mode, bling, impressing your neighbours,…
The PCB is as wide as the RGB LED modules themselves, with enough space above and below for mounting holes. This means that the modules can easily be chained horizontally in order to create type crawls. If you cut off the top and bottom mounting holesalong the line that is printed on the PCB then you can also create larger screens extending in two dimensions.
mb_rgb-led_matrix_8x8.1407169906.txt.gz · Last modified: 2014/08/04 16:31 by ilmenator
