mbhp
MBHP: The MIDIbox Hardware Platform
The hardware of all MIDIbox projects can be assembled in a modular way. Some projects have special designed modules, others only require a Core Module. Every project needs at least one Core.
An official overview of the available modules can be found here: MBHP µCApps
Modules Overview
<box 99% blue|Core MicroController Modules>
Outdated
</box>
<box 47% left green|Analog Inputs / Outputs>
- AINSER8 Module Multi Analog Input
- AINSER64 Module Multi Analog Input extended
- AIN Module Analog Input (0-5V)
- AOUT Module Analog Output Voltages (eg Control Voltages)
- AOUT LC Module A Low-Cost AOUT
- MF Module to control motor faders
</box>
<box 47% right red|Digital Inputs / Outputs>
- DIN Module Digital Input
- DOUT Module Digital Output
- LCD Module Liquid Crystal Display
- LTC Module MIDI LED +Out/Thru
- IIC Modules to communicate to other (microcontroller) devices via I2C
- USB Modules PC/USB Interface
Expired
- BankStick Memory module to store settings
</box>
<box 47% left orange|Sound Synthesis Modules>
- SID Module for the famous C64 sound chip
- OPL3 Module for the FM-Chips YMF262 and YAC512
- IIC SpeakJet Module for the SpeakJet sound chip
</box>
For Developers
If you have somehow improved a PCB layout, please submit your changes here:
- PCB Layout Improvements for MBHP Modules
mbhp.1470243500.txt.gz · Last modified: 2016/08/03 16:58 by psykhaze
